Object Version ACL
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Setting an ACL for an Object Version
You can call ObsClient.setObjectAcl to pass the version ID (versionId) to set the ACL for an object version. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Set the object version ACL to public read by specifying a pre-defined ACL.
obsClient.setObjectAcl("bucketname", "objectname", AccessControlList.REST_CANNED_PUBLIC_READ, "versionid");
AccessControlList acl = new AccessControlList();
Owner owner = new Owner();
owner.setId("ownerid");
acl.setOwner(owner);
// Grant the READ permission to all users.
acl.grantPermission(GroupGrantee.ALL_USERS, Permission.PERMISSION_READ);
// Set the ACL for the object version.
obsClient.setObjectAcl("bucketname", "objectname", acl, "versionid");
The owner or grantee ID needed in the ACL indicates the account ID, which can be viewed on the My Credentials page of OBS Console.
Obtaining the ACL of an Object Version
You can call ObsClient.getObjectAcl to pass the version ID (versionId) to obtain the ACL of an object version. Sample code is as follows:
AccessControlList acl = obsClient.getObjectAcl("bucketname", "objectname", "versionid");
System.out.println(acl);
