Rewriting Response Headers
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
When downloading an object, you can rewrite some HTTP/HTTPS response headers. The following table lists rewritable response headers.
| Parameter | Description | Method in OBS Android SDK |
| contentType | Rewrites Content-Type in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setContentType |
| contentLanguage | Rewrites Content-Language in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setContentLanguage |
| expires | Rewrites Expires in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setExpires |
| cacheControl | Rewrites Cache-Control in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setCacheControl |
| contentDisposition | Rewrites Content-Disposition in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setContentDisposition |
| contentEncoding | Rewrites Content-Encoding in HTTP/HTTPS responses. | ObjectRepleaceMetadata.setContentEncoding |
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
GetObjectRequest request = new GetObjectRequest("bucketname", "objectname");
ObjectRepleaceMetadata replaceMetadata = new ObjectRepleaceMetadata();
replaceMetadata.setContentType("image/jpeg");
request.setReplaceMetadata(replaceMetadata);
ObsObject obsObject = obsClient.getObject(request);
Log.i("GetObject", object.getMetadata().getContentType());
obsObject.getObjectContent().close(); What is your overall rating for this page?
