Updated on 2026-09-20 GMT+08:00
Downloading an Object
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
This example downloads object objectname from bucket bucketname.
The example code is as follows:
ObsObject obsObject = obsClient.getObject("bucketname", "objectname");
InputStream content = obsObject.getObjectContent();
if (content != null)
BufferedReader reader = new BufferedReader(new InputStreamReader(content));
while (true)
String line = reader.readLine();
if (line == null)
break;
Log.i("GetObject", "\n" + line);
reader.close();
- When you call ObsClient.getObject, an instance of ObsObject will be returned. This instance contains the content and properties of the object.
- When you call ObsObject.getObjectContent to obtain an object input stream, you can read the input stream to obtain its contents. Close the input stream after use.
- For more information, see Object Download Overview.
Parent topic: Quick Start
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
