- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Show all
Overview
The DCC category and type define the DCC configuration and determine the type and number of ECSs you can create in a DCC.
The DCC configuration includes the number of CPUs (sockets), number of physical cores, hardware configuration (CPU model and memory size), and number of vCPUs. Buy DCCs of desired specifications based on the site requirements.
Currently, the following DCC categories are supported:
