Notes and Constraints
Updated on 2024-11-08 GMT+08:00
This section describes the notes and constraints on using CCE.
Clusters and Nodes
  • After a cluster is created, the following items cannot be changed:
    • Cluster type: For example, a CCE standard cluster cannot be changed to a CCE Turbo cluster.
    • Number of master nodes: For example, a non-HA cluster (with one master node) cannot be changed to an HA cluster (with three master nodes).
    • AZ where a master node is deployed
    • Network configuration of the cluster, such as the VPC, subnet, container CIDR block, Service CIDR block, IPv6 settings, and kube-proxy (forwarding) settings
    • Network model: For example, a container tunnel network cannot be changed to a VPC network.
  • The ECS nodes created on CCE can be billed on a pay-per-use or yearly/monthly basis. Other resources such as load balancers are billed on a pay-per-use basis. If an involved service allows you to change the billing mode from pay-per-use to yearly/monthly, the billing mode can be changed on the service console.
  • If yearly/monthly ECS nodes are managed in a cluster, you are not allowed to renew them on the CCE console. Instead, renew the ECSs on the ECS console.
  • CCE underlying resources such as ECS nodes are limited by quota and their inventory. It is possible that only some nodes are created during cluster creation, cluster scaling, or auto scaling.
  • ECS node specifications: CPU ≥ 2 cores, memory ≥ 4 GiB
  • To access a CCE cluster through a VPN, ensure that the VPN CIDR block does not conflict with the VPC CIDR block where the cluster resides and the container CIDR block.
Networks
  • By default, a NodePort Service is accessed within a VPC. To access a NodePort Service through the Internet, bind an EIP to the node in the cluster beforehand.
  • LoadBalancer Services allow workloads to be accessed from public networks through ELB. This access mode has the following restrictions:
    • Automatically created load balancers should not be used by other resources. Otherwise, these load balancers cannot be completely deleted.
    • Do not change the listener name for the load balancer in clusters of v1.15 and earlier. Otherwise, the load balancer cannot be accessed.
  • Constraints on network policies:
    • Only clusters that use the tunnel network model support network policies. Network policies are classified into the following types:
      • Ingress: All versions support this type.
      • Egress: The cluster must be of v1.23 or later.
    • Network isolation is not supported for IPv6 addresses.
    • If you upgrade a CCE cluster to a version that supports egress rules in in-place mode, the rules will not work because the node OS is not upgraded. In this case, reset the node.
Storage Volumes
  • Constraints on EVS volumes:
    • EVS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If an EVS disk is attached to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, select only one pod when creating a Deployment that uses EVS disks.
    • For clusters earlier than v1.19.10, if an HPA policy is used to scale out a workload with EVS volumes mounted, the existing pods cannot be read or written when a new pod is scheduled to another node.
      For clusters of v1.19.10 and later, if an HPA policy is used to scale out a workload with EVS volumes mounted, a new pod cannot be started because EVS disks cannot be attached.
  • Constraints on SFS volumes:
    • Multiple PVs can use the same SFS or SFS Turbo file system with the following restrictions:
      • Do not mount the PVCs/PVs that use the same underlying SFS or SFS Turbo volume to one pod. This will lead to a pod startup failure because not all PVCs can be mounted to the pod due to the same volumeHandle value.
      • The persistentVolumeReclaimPolicy parameter in the PVs must be set to Retain. Otherwise, when a PV is deleted, the associated underlying volume may be deleted. In this case, other PVs associated with the underlying volume malfunction.
      • When the underlying volume is repeatedly used, enable isolation and protection for ReadWriteMany at the application layer to prevent data overwriting and loss.
    • If SFS 3.0 is used, the Everest add-on of v2.0.9 or later must be installed in the cluster.
    • If SFS 3.0 is used, the owner group and permission of the mount point cannot be modified. The default owner of the mount point is user root.
    • If SFS 3.0 is used, there may be a latency during the creation or deletion of PVCs and PVs. The billing duration is determined by the time when the SFS system is created or deleted on the SFS console.
    • If the reclamation policy of SFS 3.0 is set to Delete, PVs and PVCs can be properly deleted only after all files are manually deleted from the mounted SFS system.
  • Constraints on OBS volumes:
    • If OBS volumes are used, the owner group and permission of the mount point cannot be modified.
    • Every time an OBS volume is mounted to a workload through a PVC, a resident process is created in the backend. When a workload uses too many OBS volumes or reads and writes a large number of object storage files, resident processes will consume a significant amount of memory. To ensure stable running of the workload, make sure that the number of OBS volumes used does not exceed the requested memory. For example, if the workload requests for 4 GiB of memory, the number of OBS volumes should be no more than 4.
    • Kata containers do not support OBS volumes.
    • Hard links are not supported when common buckets are mounted.
  • Constraints on local PVs:
    • Local PVs are supported only when the cluster version is v1.21.2-r0 or later and the Everest add-on version is 2.1.23 or later. Version 2.1.23 or later is recommended.
    • Removing, deleting, resetting, or scaling in a node will cause the PVC/PV data of the local PV associated with the node to be lost, which cannot be restored or used again. In these scenarios, the pod that uses the local PV is evicted from the node. A new pod will be created and stays in the pending state. This is because the PVC used by the pod has a node label, due to which the pod cannot be scheduled. After the node is reset, the pod may be scheduled to the reset node. In this case, the pod remains in the creating state because the underlying logical volume corresponding to the PVC does not exist.
    • Do not manually delete the corresponding storage pool or detach data disks from the node. Otherwise, exceptions such as data loss may occur.
    • A local PV cannot be mounted to multiple workloads or jobs at the same time.
  • Constraints on local EVs:
    • Local EVs are supported only when the cluster version is v1.21.2-r0 or later and the Everest add-on version is 1.2.29 or later.
    • Ensure that the /var/lib/kubelet/pods/ directory is not mounted to the pod on the node. Otherwise, the pod, mounted with such volumes, may fail to be deleted.
  • Constraints on snapshots and backups:
    • The snapshot function is available only for clusters of v1.15 or later and requires the CSI-based Everest add-on.
    • The subtype (common I/O, high I/O, or ultra-high I/O), disk mode (VBD or SCSI), data encryption, sharing status, and capacity of an EVS disk created from a snapshot must be the same as those of the disk associated with the snapshot. These attributes cannot be modified after being checked or configured.
    • Snapshots can be created only for EVS disks that are available or in use, and a maximum of seven snapshots can be created for a single EVS disk.
    • Snapshots can be created only for PVCs created using the storage class (whose name starts with csi) provided by the Everest add-on. Snapshots cannot be created for PVCs created using the FlexVolume storage class whose name is ssd, sas, or sata.
    • Snapshot data of encrypted disks is stored encrypted, and that of non-encrypted disks is stored non-encrypted.
Add-ons
CCE uses Helm charts to deploy add-ons. To modify or upgrade an add-on, perform operations on the Add-ons page or use open add-on management APIs. Do not directly modify add-on resources on the backend. Otherwise, add-on exceptions or other unexpected problems may occur.
CCE Cluster Resources
There are resource quotas for your CCE clusters in each region.
Item
Constraints on Common Users
Exception Handling
Total number of clusters in a region
50
Submit a service ticket to request for increasing the quota.
Number of nodes in a cluster (cluster management scale)
A maximum of 50, 200, 1000, or 2000 nodes can be selected.
Submit a service ticket to request for increasing the quota. A maximum of 10,000 nodes are supported.
Maximum number of pods on a node
256
In a CCE Turbo cluster, the maximum number of pods on a node is determined by the number of NICs that can be used by the node.
To increase the deployment density on a node, submit a service ticket to increase the maximum number of pods on a node. A maximum of 512 pods are supported.
Maximum number of pods managed by a cluster
100,000 pods
If the number of supported pods cannot meet your requirements, submit a service ticket to request for technical support to optimize your clusters based on the service model.
Cluster Capacity Limit
The capacity of a cluster is made up of various resource types, including container groups (pods), cloud storage instances (persistent volumes), and Services. Additionally, the size of these resource objects can also impact the cluster capacity.
For example:
  • If there are too many pods, the maximum number of pods will decrease within a certain performance range.
  • As the number of pods approaches the upper limit, the upper limits of other resource types in the cluster will also decrease accordingly.
Since clusters in actual application environments contain multiple resource types, it is possible that the number of resources for a single type may not reach its upper limit. It is important to monitor cluster resource usage regularly and plan and manage the resources effectively to ensure the best performance of all resources. If the current specifications do not meet your requirements, you can scale out the cluster to ensure stability.
Dependent Underlying Cloud Resources
Category
Item
Pods
1000
Cores
8000
RAM capacity (MB)
16,384,000
VPCs per account
5
Subnets per account
100
Security groups per account
100
Security group rules per account
5000
Routes per route table
100
Routes per VPC
100
VPC peering connections per region
50
Network ACLs per account
200
Layer 2 connection gateways per account
5
Load balancing
Elastic load balancers
50
Load balancer listeners
100
Load balancer certificates
120
Load balancer forwarding policies
500
Load balancer backend host group
500
Load balancer backend server
500
If the current quota cannot meet your requirements, submit a service ticket to request for increasing your quota.
