Updated on 2025-10-24 GMT+08:00
Notes and Constraints
Use Restrictions
  • Worker nodes in CCE Autopilot clusters are fully hosted. For this reason, certain features like hostPath and hostNetwork, which rely on node features, are not supported.
    Unavailable Feature
    Recommended Alternative Solution
    DaemonSet
    Deploys pods on each node.
    Deploy multiple images in a pod using sidecars.
    Setting hostPath in a pod
    Mounts local files of a node to a container.
    Use emptyDir or cloud storage of any type.
    Setting hostNetwork in a pod
    Maps a node port to a container port.
    Use Services of the LoadBalancer type.
    NodePort Service
    Makes a node port open to access containers.
  • When CCE Autopilot is used, each pod in the workload has 30-GiB of free disk space (with an IOPS upper limit of 2,500 and a burst limit of 16,000) by default. In addition to the resources reserved for the OS and CCE platform, the total available space for images, containers, and temporary storage is about 20 GiB. If the container image is too large (generally greater than 5 GiB) or a large number of files are created in the container root directory or temporary storage, you are advised to increase the ephemeral storage capacity of the pod. For details, see Increasing the Ephemeral Storage Space of a Pod.
  • By default, no more than 1,000 pods can be created in a CCE Autopilot cluster. The add-on instances may occupy some pod quotas. You need to plan the pod quota appropriately. To increase the quota, submit a service ticket.
  • If a CCE Autopilot cluster is used, workloads that use Arm images are not supported.
Cloud Product Quota Limits
The table below shows the maximum number of resources that can be created per account in a region.
Category
Item
Quota
CCE cluster
Total number of clusters
50
VPC
VPCs
5
Subnets
100
Security groups
100
Security group rules
5000
Routes per route table
100
Routes per VPC
100
VPC peering connections
50
Network ACLs
200
ELB
Load balancers
50
Load balancer listeners
100
Load balancer certificates
120
Load balancer forwarding policies
500
Load balancer backend server groups
500
Load balancer backend servers
500
VPCEP
Endpoints
50
DNS
Private zones
50
DNS record sets
500
If your current quota is insufficient, submit a service ticket to request an increase.
