- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Product Highlights
Intelligent, Reliable, Automated O&M
CCE Autopilot enhances your cluster experience with stable, secure, and intelligent features, such as automatic version upgrades, vulnerability fixing, and parameter tuning. CCE Autopilot is a serverless solution that simplifies capacity planning and node purchasing for fully hosted clusters. You do not need to manage or maintain the underlying resources, so there is much less O&M to deal with. You can focus on developing and deploying service logic.
Excellent Scalability with Continuous Iteration
CCE Autopilot prioritizes performance by setting up a serverless resource foundation in collaboration with underlying services. It uses multi-level resource pool pre-provisioning technology to meet diverse heterogeneous resource requirements and continuously improves performance through iterations. There is no need for you to plan or reserve resources beforehand to handle traffic bursts, seasonal fluctuations, and long-term service growth. Containers can be automatically scaled in or out within seconds based on your workloads. This ensures continuity and the optimal performance for your services. With CCE Autopilot, you can quickly launch new applications or services in response to market changes.
Compatibility with Cloud Native Open-Source Ecosystem
CCE Autopilot leverages a serverless architecture and a cloud native open source ecosystem to offer serverless clusters that are compatible with the Kubernetes ecosystem. This allows you to flexibly expand functions as needed. CCE Autopilot can also keep up with all Kubernetes community versions, so you always get the latest technical updates and security patches in a timely manner. It makes it easier to keep current with cutting-edge technologies. CCE Autopilot is always integrating mainstream open source security, application management, scalability, CI/CD, and AI software, such as OPA Gatekeeper and Knative. Integrating all these tools gets you an out-of-the-box application framework for easier application management.
Flexible Specifications and Per-Second Billing
CCE Autopilot delivers a flexible, efficient, and cost-effective cloud service experience. It dynamically adjusts cluster specifications and removes traditional specification tier limitations. You can easily adjust specifications with as little as 0.25 vCPUs and configure any resource ratio needed. The pay-per-use billing of CCE Autopilot (measured in seconds) means you save money because you only pay for the resources you actually use.
Security Isolation and Automatic Warnings
CCE Autopilot, built on the QingTian architecture, improves application security through virtual machine isolation. It provides a simplified and secure running environment using a dedicated container OS. With the underlying resource pool, CCE Autopilot supports quick fault isolation and rectification, ensuring continuous, secure, and stable application performance. Built-in automatic warnings can identify and prevent overloads on the control plane in a timely manner. The control plane components can be automatically scaled out to handle extra loads, ensuring service stability and reliability.
