- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
What Is a CCE Autopilot Cluster?
Introduction
CCE Autopilot allows you to create serverless clusters that offer optimized Kubernetes compatibility and free you from O&M. After a CCE Autopilot cluster is created, you can deploy applications without purchasing nodes or maintaining the deployment, management, and security of nodes. You only need to focus on the implementation of application service logic, which greatly reduces your O&M costs and improves the reliability and scalability of applications.
Product Architecture
Challenges with Traditional Serverful Container Clusters
Container technologies are driving the transformation of enterprise IT architecture in cloud computing due to their lightweight nature and high efficiency. However, traditional container services that rely on the serverful infrastructure are revealing the following issues, which severely hinder the pace of enterprise innovation:
- O&M management: Enterprises need to manually manage server resource allocation and expansion, which involves complex capacity planning and resource scheduling, as well as continuous O&M such as node monitoring, troubleshooting, and system upgrades. This is expensive and requires a large workforce and many resources.
- Scalability: Enterprises need to create joint scaling policies for nodes and workloads. However, worker nodes must be scaled beforehand, which takes a few minutes and affects efficiency and response speed.
- Cost control: Enterprises need to allocate resources to nodes in advance. Unfortunately, those resources are often underutilized, or when there are heavy workloads, resources may be insufficient. This makes it hard to maximize cost effectiveness.
Benefits of Using the CCE Autopilot Cluster Architecture
Compared with CCE standard and Turbo clusters, CCE Autopilot clusters have the following advantages:
- Serverless evolution: Worker nodes are fully hosted on Huawei Cloud, so you do not have to maintain node deployment, manage nodes, or worry about security issues. Cluster flavors are adaptive.
- Resource pooling: A serverless converged resource pool is used to manage resources such as CPUs, memory, and GPUs, reducing resource fragments and enabling on-demand use of container resources.
- Comprehensive performance optimization: Resource pool resources are pre-provisioned to enable fast resource allocation, allowing for the scaling of more containers within seconds based on workload size.
Comparison Between CCE Autopilot Clusters and Traditional Serverful Container Clusters
Category |
Serverless Container Cluster |
Traditional Serverful Container Cluster |
CCE Autopilot |
CCE Standard |
CCE Turbo |
Node management |
Worker nodes are fully managed. CCE Autopilot takes care of node scaling and pre-binding. |
You need to take care of the management and O&M of worker nodes. |
Node OSs |
There are dedicated OSs that use containerd as the container engine. |
You can select an OS and container engine. |
Node specifications |
Node specifications are adaptive to the workload scale. |
You can select the node specifications as needed. |
Node upgrade and maintenance |
Nodes are upgraded and recovered automatically. |
Nodes need to be reset for upgrade. |
Container network model |
Cloud native 2.0 network |
Network performance |
The VPC network and container network are flattened into one for zero performance loss. |
The container network is overlaid with the VPC network, causing performance loss. |
Network isolation |
Pods can be associated with security groups for isolation. |
