- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
On this page
Show all
Relationship with Other Cloud Services
CAE is a one-stop cloud application platform. Its core service functions cover infrastructure, storage, database, software repository, monitoring and O&M, and middleware services.
CAE:
- Interconnects with source code repositories, such as CodeArts, GitHub, Gitee, GitLab, and Bitbucket. After it is bound, you can directly pull up the source code from source code repositories for building.
- Integrates the software center and archives the built software packages (or image packages) to the corresponding repositories and organizations.
- Integrates Cloud Service Engine (CSE) to register component instances with CSE. CSE provides all-scenario capabilities such as service registration, governance, and configuration management. CSE enables users to quickly develop microservices and perform high-availability O&M.
- Integrates Rational Database Service (RDS) to store data exchanged between application components to RDS. RDS is a professional database management platform for users to easily set up and expand cloud databases.
- Provides application component monitoring, O&M management, and log services.
- Interconnects with Object Storage Service (OBS) for specified functions. CAE enables users to create and query buckets in OBS, and upload, query, and delete object files in buckets. They also can use CAE to create and query parallel file systems in OBS.
