Updated on 2025-11-17 GMT+08:00
Specifications
Dedicated Gateway Specifications
The query per second (QPS) throughput of a dedicated gateway is affected by multiple factors, such as the response size, whether HTTPS access is enabled, and whether gzip compression is enabled. The following table lists the APIG QPS reference values at 30% CPU usage in non-authentication and single node scenarios.
The security watermark enables APIG to maintain high throughput and low latency even when the burst traffic doubles.
Table 1 QPS Reference
Edition
Basic
Professional
Enterprise
Platinum
Platinum 2
Connection Type
Number of Response Bytes (KB)
Whether to Use HTTPS
Whether to Use gzip
QPS Reference at 30% CPU Usage
Non-persistent connection
No
No
1,600
3,600
9,000
55,000
72,000
Yes
No
1,000
1,100
2,800
16,000
20,000
Persistent connection
No
No
2,500
4,200
13,000
79,000
105,000
Yes
No
2,000
4,000
11,000
67,000
95,000
10
No
No
2,200
4,000
10,000
67,000
85,000
Yes
No
1,800
3,800
9,500
65,000
80,000
The bandwidth and private network connections vary depending on the gateway edition. Refer to the following table for optimal settings.
Table 2 Bandwidth and connections
Edition
Bandwidth
Private Network Connections per Second
Basic
Single-AZ: 50 Mbit/s
Dual-AZ or more: 100 Mbit/s
1,000
Professional
Single-AZ: 100 Mbit/s
Dual-AZ or more: 200 Mbit/s
1,000
Enterprise
Single-AZ: 200 Mbit/s
Dual-AZ or more: 400 Mbit/s
1,000
Platinum
Single-AZ: 400 Mbit/s
Dual-AZ or more: 800 Mbit/s
1,000
Platinum 2
Single-AZ: 2 Gbit/s
Dual-AZ or more: 4 Gbit/s
1,000
Platinum 3
Single-AZ: 2 Gbit/s
1,000
Platinum 4
Single-AZ: 2 Gbit/s
1,000
Platinum 5
Single-AZ: 2 Gbit/s
1,000
Platinum 6
Single-AZ: 2 Gbit/s
1,000
Platinum 7
Single-AZ: 2 Gbit/s
1,000
Platinum 8
Single-AZ: 2 Gbit/s
1,000
  • If some new features (such as gateway specification modification and circuit breaker policy) are not available for the gateway, contact technical support to upgrade it.
  • The default API-related quotas of dedicated gateways are the same as those of the shared gateway.
  • For details about how to modify the specifications of a dedicated gateway, see Modifying Gateway Specifications.
  • Currently, platinum edition 2 and later are available only in CN North-Beijing4, CN East2, ME-Riyadh, and CN-Hong Kong.
Shared Gateway (Old Console) Specifications
The shared gateway on the old console does not provide any specification settings. View the quotas for creating and using APIs in Notes and Constraints.
The shared gateway has been brought offline and can be used only by existing users. You are advised to use dedicated gateways.
Differences Between Dedicated and Shared Gateways
APIG provides a shared gateway and dedicated gateways. You can use the shared gateway right out of the box or purchase dedicated gateways to manage APIs.
Dedicated gateways facilitate decoupling internal systems within an enterprise. Services deployed in VPCs communicate with each other through RESTful APIs with high network security. Dedicated gateways support the deployment of frontend or backend services on public networks, and these services can be accessed using elastic IPs (EIPs).
Table 3 Basic differences between the shared and dedicated API gateways
Dimension
Shared Gateway
Dedicated Gateway
Billing item
API calls and public network traffic.
Specifications and public network egress bandwidth.
Network access
APIs are accessed over public networks.
Gateways run in VPCs. APIs in a VPC are called using the access address of the VPC.
You can enable access to API resources in a gateway over public networks or access to resources on public networks through APIs in a gateway.
Target users
Small enterprises that have low physical isolation requirements and want to selectively expose API capabilities.
Large and medium enterprises that want to selectively expose and call internal APIs. Dedicated gateways are deployed in physically isolated clusters with different bandwidths for inbound and outbound access.
The following table shows the functional differences between the shared and dedicated API gateways.
Table 4 Functional differences between the shared and dedicated API gateways
Category
Feature
Shared Gateway
Dedicated Gateway
Basic functions
Refined request throttling
Access control by IP address and account
Security authentication
API lifecycle management
Custom domain names
Swagger API import and export
Load balance channels
API parameter orchestration
API group variable management
Advanced functions
Custom authentication
Policy-based routing
API monitoring
Backend load balancing
Internal API management
Access to backend services in private clouds
Service access through Direct Connect
Plug-ins
Log analysis
Performance indicators
Physically isolated clusters
Different bandwidths for inbound and outbound access
TPS
200
4,000–10,000
