Yearly/Monthly to Pay-per-Use
After creating a yearly/monthly cluster or node, you can change it to a pay-per-use cluster or node for more flexibility.
The pay-per-use billing takes effect only after the yearly/monthly subscription expires.
The billing mode can only be changed from yearly/monthly to pay-per-use for a CCE cluster or node whose order status is provisioned. You can view the order status on the Renewals page in Billing Center.
- Go to the Renewals page.
- Customize the search criteria.
- Under the Pay-per-Use After Expiration tab, you can view the resources that already have changed to pay-per-use upon expiration configured.
- On the Manual Renewals, Auto Renewals, and Renewals Canceled tabs, you can also change the billing mode of the resources to pay-per-use billing upon expiration.
- Change a yearly/monthly resource to pay-per-use upon expiration.
- Changing the billing mode of a single resource: Select the resource whose billing mode you want to change and choose More > Change to Pay-per-Use After Expiration in the Operation column.
Figure 1 Changing to pay-per-use billing upon expiration for a single resource
- Changing the billing mode of multiple resources at a time: Select the resources whose billing modes you want to change and click Change to Pay-per-Use After Expiration above the list.
Figure 2 Changing to pay-per-use billing upon expiration for multiple resources
- Confirm the details and click Change to Pay-per-Use.
Figure 3 Changing to pay-per-use billing upon expiration
