Buying a Package
CCE Autopilot clusters provide packages of CPU and memory required by pods. You can purchase packages to enjoy more discounts. You cannot unsubscribe from packages. Plan the resources and validity period carefully before your purchase.
For details about packages, see Package Overview.
When you purchase packages, note the following:
- Packages are billed once and effective immediately upon payment. Currently, you cannot set a future effective date or unsubscribe from the packages.
- After the packages expire, you can still use CCE Autopilot clusters. Ensure that your account balance is sufficient. The system will automatically settle the expenditures on a pay-per-use basis.
- The validity period can be one month or one year. After the validity period expires, the remaining resources cannot be used.
- Log in to the CCE console and click the cluster name to go to the Overview page. In the Autopilot Resource Package area on the right, click Buy Package.
- On the page that is displayed, select the required package specifications as prompted. For details about pod types, see Setting the Pod Type > Configuring a Workload > Workloads > User Guide.
- Confirm the specifications, click Pay Now in the lower right corner. In the displayed dialog box, click OK.
- On the Buy Cloud Container Engine (CCE) page, pay for the order as prompted.
