Updated on 2025-08-26 GMT+08:00
Applying for a DCC
The following operations guide you to apply for a Dedicated Computing Cluster (DCC).
Registering an Account
  1. Visit the Huawei Cloud website at https://www.huaweicloud.com/intl/en-us/.
  2. Click Register in the upper right corner of the page.
    On the Account Registration page, complete the registration as prompted.
Enabling DeC
Before applying for a DCC, you must enable the Dedicated Cloud (DeC) service. Therefore, reserve sufficient time for each process so that you can use the DeC service in a timely manner as expected.
Applying for a DCC
  1. Log in to the DeC console.
  2. On the Dedicated Computing Cluster page, click Apply for Resource in the upper right corner.
  3. Locate the server type you want to add, set the desired number in the Quantity column, and select a usage duration.
  4. Click Next.
  5. Confirm the configuration and click Submit.
  6. After the task is successfully submitted, the system generates a payment order.
    Once your payment is verified, the administrator will enable your required resources as soon as possible. After your resources are enabled, the order is in the completed state.
