On this page
Help Center/ VPC Endpoint/ User Guide (Kuala Lumpur Region)/ VPC Endpoint Services/ Viewing the Summary of a VPC Endpoint Service
Updated on 2023-12-20 GMT+08:00
This section describes how to query the summary of a VPC endpoint service, including its name, ID, backend resource type, backend resource name, VPC, status, connection approval, service type, and creation time.
  2. Click in the upper left corner and select the required region and project.
  1. Click Service List and choose Networking > VPC Endpoint.
  2. In the navigation pane on the left, choose VPC Endpoint > VPC Endpoint Services.
    Locate the target VPC endpoint service by entering a filter in the search box in the upper right corner:
    • Search by name or ID.
      1. Select Name or ID in the filter box.
      2. Enter a keyword in the search box.
      3. Click to start the search.
        VPC endpoint services containing the keyword are displayed.
    • Search by tag.
      1. Click to the right of Search by Tag.
      2. Enter a tag and a value.
        You can also select a key or value from the drop-down list.
        You can use a maximum of 10 tags to search for a VPC endpoint service.
      3. Click Search.
        VPC endpoint services containing the specified tag are displayed.
        If you set multiple tags, VPC endpoint services containing all the specified tags will be displayed.
  3. In the VPC endpoint service list, locate the target VPC endpoint service and click its name to view its details.
    Table 1 describes the parameters displayed on the VPC endpoint service details page.
    Table 1 Parameters contained in the details of a VPC endpoint service
    Tab
    Summary
    Name
    Specifies the name of the VPC endpoint service.
    ID
    Specifies the ID of the VPC endpoint service.
    Backend Resource Type
    Specifies the type of the backend resource that provides services.
    Backend Resource Name
    Specifies the name of the backend resource that provides services to be accessed.
    VPC
    Specifies the VPC where the VPC endpoint service is to be deployed.
    Status
    Specifies the status of the VPC endpoint service.
    Connection Approval
    Specifies whether connection approval is required.
    Service Type
    Specifies the type of the VPC endpoint service.
    Created
    Specifies the creation time of the VPC endpoint service.
    Connection Management
    VPC Endpoint ID
    Specifies the ID of the VPC endpoint.
    Packet ID
    Specifies the identifier of the VPC endpoint ID.
    Status
    Specifies the status of the VPC endpoint.
    For details about statuses of VPC endpoint services and VPC endpoints, see What Statuses Are There for a VPC Endpoint Service and VPC Endpoint?
    Owner
    Specifies the ID of the VPC endpoint owner.
    Created
    Specifies the creation time of the VPC endpoint.
    Operation
    Specifies whether to allow a VPC endpoint to connect to a VPC endpoint service. The option can be Accept or Reject.
    Permission Management
    Authorized ID
    Specifies the authorized ID for connecting to the VPC endpoint. The ID can also be *.
    If you add an asterisk (*) to the whitelist, it means that all users can access the VPC endpoint service.
    Operation
    Specifies whether to delete an authorized from the whitelist.
    Port Mapping
    Protocol
    Specifies the protocol used for communications between the VPC endpoint service and a VPC endpoint.
    Service Port
    Specifies the port provided by the backend service bound to the VPC endpoint service.
    Terminal Port
    Specifies the port provided by the VPC endpoint, allowing you to access the VPC endpoint service.
    Tags
    Key
    Specifies the tag key of the VPC endpoint service.
    Value
    Specifies the tag value of the VPC endpoint service.
    Operation
    Specifies the operation to be performed on the VPC endpoint service tag. You can click Edit or Delete.
