- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
Show all
Service Advantages
SMN has the following advantages over any traditional messaging systems.
Item |
SMN |
Traditional Messaging System |
Simplicity |
SMN provides three basic APIs to create topics, add subscriptions, and publish messages and can be quickly integrated with your services. It enables you to send messages in substantial quantity and do not require highly skilled development. |
A self-developed messaging system is expensive and takes long time to be integrated with your services. Its APIs are complex and hard to use. |
Stability and reliability |
SMN stores messages in multiple data centers and supports transparent topic migration. Once a message fails to deliver, SMN saves it in a message queue and tries to deliver it again. If one service node is faulty, your requests are automatically processed by another available node. |
A traditional messaging system cannot achieve the stability and reliability required by critical services and does not provide measures to ensure service continuity. |
Multiple message types |
You publish a message once, and SMN delivers it to endpoints in various message types. |
You need to develop separate messaging systems in multiple types to send email, HTTP, or HTTPS notifications. |
Security |
SMN isolates data based on topics and prevents any unauthorized users from accessing message queues, thereby protecting your service data. |
Service data is potentially exposed to unauthorized access due to lack of effective protection mechanisms. |
