Updated on 2025-11-03 GMT+08:00
Viewing a File System
You can search for file systems by file system name keyword and view their basic information.
  1. Log in to the SFS console.
  2. In the file system list, view the file systems you have created. Table 1 describes the file system parameters.
    Table 1 Parameter description
    Name
    Name of the created file system
    AZ
    Availability zone where the file system is located
    Status
    Possible values are Available, Creation failed, Unavailable, Frozen, Creating, Deleting.
    Type
    File system type
    Protocol Type
    File system protocol, which is NFS
    Used/Total Capacity (GB)
    The used capacity includes metadata and user data, so it differs slightly from the amount of data you have stored in the file system.
    The total capacity is the file system capacity you applied for. The actual available capacity is slightly less than the total capacity because stored data generates metadata, which takes up some space.
    Encryption
    Encryption status of the file system. The value can be Yes or No.
    Enterprise Project
    Enterprise project to which the file system belongs
    Shared Path
    File system address
    Operation
    Includes the Expand Capacity, View Metric, and Delete buttons.
  3. (Optional) Search for the specified file system by file system name.
