SFS Basic Concepts
Before you start, understand the following concepts.
NFS
Network File System (NFS) is a distributed file system protocol that allows different computers and operating systems to share data over a network.
File System
A file system provides users with shared file storage through NFS. It is used for accessing network files remotely. After you create a file system on the console, you can mount the file system on multiple cloud servers and access the file system from the servers through the standard POSIX.
POSIX
Portable Operating System Interface (POSIX) is a set of interrelated standards specified by Institute of Electrical and Electronics Engineers (IEEE) to define the application programming interface (API) for software compatible with variants of the UNIX operating system. POSIX is intended to achieve software portability at the source code level. That is, a program written for a POSIX compatible operating system may be compiled and executed on any other POSIX operating system.
DHCP
Dynamic Host Configuration Protocol (DHCP) is a LAN network protocol. The server controls an IP address range, and a client can automatically obtain the IP address and subnet mask allocated by the server when logging in to the server. By default, DHCP is not automatically installed as a service component of Windows Server. Manual installation and configuration are required.
