Failed to Create an SFS Turbo File System
Symptom
An SFS Turbo file system fails to be created.
Troubleshooting
Possible causes are described here in order of how likely they are to occur.
If the fault persists after you have ruled out one cause, move on to the next one in the list.
        Possible Cause  |
        Solution  |
        The quota is insufficient.  |
        The number of created file systems has reached the upper limit. Apply for a higher quota.  |
        The subnet does not have sufficient IP addresses.  |
        If the IP addresses in the subnet are insufficient, change the subnet or release IP addresses in the subnet.  |
        The background resources are insufficient.  |
        Background resources, such as compute and storage resources, have reached the upper limit. Seek for technical consultation.  |
