Tags
This section describes how to add tags to existing SFS Turbo file systems. You can also add tags when creating file systems. For details, see Create a File System.
Tags are used to identify and classify file systems.
- Tags are composed of key-value pairs.
- A tag key can contain a maximum of 128 characters and cannot be left blank. It can contain letters, digits, spaces, and special characters (_.:=+-@), but cannot start or end with a space or start with _sys_.
 - A tag value can contain a maximum of 255 characters and can be an empty string. It can contain letters, digits, spaces, and special characters (_.:/=+-@), but cannot start or end with a space.
 - You can add a maximum of 20 tags to a file system.
 - Tag keys of the same file system must be unique.
- Log in to the SFS console.
 - In the file system list, find the file system to which you want to add tags and click the name of it. The file system details page is displayed.
 - Click the Tags tab.
 - On the Tags tab, click Edit Tag.
The Edit Tag dialog box is displayed.
 - Add the key and value of the tag and click OK.
- Key: This parameter is mandatory.
 - Value: This parameter is optional.
Return to the tag list, and you can see the tags you have just added. You can edit and delete the added tags.
