Creating and Copying a Security Report
SecMaster provides you with security reports. You can monitor security status of your resources promptly via security reports.
This section describes how to create a security report and how to quickly create a security report by copying an existing template.
You have purchased SecMaster, and your subscription is still valid.
Creating a Report
 - Click
 in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
 - In the navigation pane on the left, choose .
 - On the Security Reports page, click
 to go to the basic configuration page. - Configure basic information of the report.
Table 1 Report parameters Parameter
Report Name
Name of the report you want to create.
- The report name can contain letters, digits, underscores (_), and hyphens (-) only.
- Enter 1 to 30 characters.
Schedule
Select a report schedule.
- Daily: SecMaster collects security information from 00:00:00 to 23:59:59 of the previous day by default.
 - Weekly: SecMaster collects statistics on security information from 00:00:00 on Monday to 23:59:59 on Sunday of the previous week.
 - Monthly: SecMaster collects statistics on security information from 00:00:00 on the first day to 23:59:59 on the last day of the previous month.
 - Custom: Customize a time range.
Data Scope
If you select the daily, weekly, or monthly schedule, the data scope is specified by default.
If you select the custom schedule, you need to specify a data scope.
 - Click Next: Report Choose in the lower right corner.
 - On the Report Selection page, select a report template from the left. Then, you can preview the report layout in the right pane.
If Schedule is set to Daily, select the Daily Report layout.
If Schedule is set to Weekly, select the Weekly Report layout.
If Schedule is set to Monthly, select the Monthly Report layout.
 - Click Complete in the lower right corner. On the displayed Security Reports page, view the created report.
 - You can also download, share, edit, copy, and delete a security report on the Security Reports page.
- Download a report: On the Security Reports page, click More in the lower right corner of the report you want to download and choose Download from the drop-down list. On the report preview page displayed, click Download in the upper part. In the dialog box displayed, select a report format and click OK. The system automatically downloads the report in the format you select to your local PC.
 - Share a report: On the Security Reports page, click More in the lower right corner of the report you want to share, and click Share in the drop-down list. In the dialog box displayed, click Copy to share the report.
Then, click OK to close the dialog box.
 - Edit a report: On the Security Reports page, click Edit under the report to be edited. For details, see Managing Security Reports.
 - Copy a report: On the Security Reports page, click Copy under the report you want to copy. For details, see Copying a Report.
 - Delete a report: On the Security Reports page, click Delete under the report you want to delete. For details, see Managing Security Reports.
Copying a Report
 - Click
 - Select a report template and click Copy.
 - Edit basic information of the report.
 - Click Next: Select Report Template in the lower right corner. On the displayed report configuration page, modify the report content.
 - Click Complete in the lower right corner. On the displayed Security Reports page, view the newly created report.
Related Operations
- Viewing a Security Report
 - Downloading a Security Report
 - Managing Security Reports: You can enable, disable, edit, and delete a security report.
