Overview
SecMaster can scan cloud services for risks in key configuration items, report scan results by category, generate alerts for incidents, and provide hardening suggestions and guidelines.
SecMaster can check key cloud service configurations for your workloads on the cloud based on preconfigured compliance packs, Cloud Security Compliance Check 1.0, DJCP 2.0 Level 3 Requirements, Network Security, General Data Protection Regulation, OS Configuration Baseline, and Cloud Security Configuration. In addition, you can add custom check items and compliance packs to meet your own needs.
Compliance Pack |
Description |
Applicable Region |
Category |
Domain |
Cloud Security Compliance Check 1.0 |
This compliance pack automates the assessment of your data security posture across four key areas: identity and access management, infrastructure security, data protection, and backup integrity. It helps you efficiently identify data security issues. |
Global |
Industry standards |
Network security |
DJCP 2.0 Level 3 Requirements |
This compliance pack provides check items and guidelines to help you evaluate your data security management. It also suggests improvements based the level 3 requirements of China's national standard GB/T 22239-2019 information security technology — Baseline for classified protection of cybersecurity. |
China |
National standards |
Network security |
Network Security |
This compliance pack offers automated security checks aligned with international best practices. It enables cloud customers to identify threats and risks across key assets—including cloud servers, web applications, object storage, and data security centers—enhancing overall network security capabilities. |
Global |
Network security |
Cloud Security Configuration |
This compliance pack automates security configuration checks for IAM, monitoring, compute (container and cloud server), network, storage, and data services against cloud security benchmarks, helping you establish and maintain a secure cloud foundation. |
Global |
Network security |
General Data Protection Regulation |
The General Data Protection Regulation (GDPR) is a comprehensive data privacy law established by the European Union to safeguard individuals' personal data and ensure its secure processing. It mandates that all organizations processing EU citizens' personal data must ensure transparent, lawful, and secure data processing practices. |
European Union |
Regional laws |
Data protection |
OS Configuration Baseline |
This compliance pack checks password complexity policies, common weak passwords, and configurations. It can detect insecure password configurations and risky configurations in key software on servers, and provide rectification suggestions for detected risks, helping you correctly handle risky configurations on servers. |
Global |
Operating systems (OSs) |
Limitations and Constraints
- Only SecMaster professional edition supports the OS Configuration Baseline compliance pack. Before using this pack, you need to enable HSS baseline log access in SecMaster and enable Automatically converts alarms for HSS baseline logs. In the navigation pane of the target workspace, choose . On the displayed page, click
next to HSS baseline and the button in the Automatically converts alarms column, and click Save. In the dialog box displayed, click OK. For more operations, see Enabling Log Access.
- SecMaster does not perform checks based on the OS Configuration Baseline compliance pack. It synchronizes the baseline inspection results from HSS. So you can view the results in SecMaster.
Baseline Check Methods
- Automated baseline checks
By default, SecMaster performs a check every three days. From 00:00 to 06:00, SecMaster checks all assets in the current region under your account based on compliance pack Cloud Security Compliance Check 1.0. The default check plan only allows you to enable or disable automatic baseline checks.
- Scheduled custom baseline checks
You can customize the automatic check period, check time, and check scope. For details, see Performing a Scheduled Baseline Check.
- Immediate baseline checks
- You can start all compliance packs in use to detect violations against automatic check items.
- You can start a check plan to detect violations against check items in the compliance pack configured in the check plan.
- You can select one or more check items and start them at once.
- Manual baseline checks
There are some manual check items included in baseline inspection. After you finish a manual check, report the check results to SecMaster. The pass rate is calculated based on results from both manual and automatic checks. For automatic check items, you can manually start specific checks.
For details about manual checks, see Performing a Manual Baseline Check.
Usage Process
The process of using baseline inspection is as follows.
No. |
Operation |
Description |
0 |
(Optional) Enabling SecMaster access to HSS baseline logs in Host Security Service. |
This operation is required only when SecMaster professional edition is in use and the OS Configuration Baseline compliance pack is enabled. For details about how to enable the compliance package, see Editing, Enabling, Disabling, or Deleting a Compliance Pack. In the navigation pane of the target workspace, choose |
1 |
SecMaster uses the default check plan to check all assets.
2 |
The baseline inspection supports periodic and immediate checks.
3 |
You can view the baseline inspection results after each manual check or automated check. You can quickly learn affected assets and details about the baseline inspection items. |
4 |
You can handle risky items based on the rectification suggestions.
