Help Center/ SecMaster/ User Guide (Kuala Lumpur Region)/ Permissions Management/ SecMaster Permissions and Supported Actions
Updated on 2025-06-26 GMT+08:00
This topic describes fine-grained permissions management for your SecMaster. If your account does not need individual IAM users, then you may skip over this section.
By default, new IAM users do not have any permissions assigned. You need to add a user to one or more groups, and assign permissions policies to these groups. Users inherit permissions from the groups to which they are added. After authorization, the user can perform specified operations on cloud services based on the permissions.
Permissions are classified into roles and policies based on the authorization granularity. A role is a coarse-grained authorization mechanism provided by IAM to define permissions based on users' job responsibilities. A policy defines permissions required to perform operations on specific cloud resources under certain conditions. IAM uses policies to perform fine-grained authorization.
Limitations and Constraints
All actions supported by SecMaster support only IAM projects but not enterprise projects.
Supported Actions
SecMaster provides system-defined policies that can be directly used in IAM. You can also create custom policies and use them to supplement system-defined policies, implementing more refined access control.
  • Permission: A statement in a policy that allows or denies certain operations.
  • Action: Specific operations that are allowed or denied.
Table 1 Read-only permissions supported
Permission
Action
Get the statistics of playbook
secmaster:playbook:getStatistics
Query playbook details
secmaster:playbook:getInstance
Show subscription version
secmaster:subscription:getVersion
Query search condition details
secmaster:searchCondition:get
Export indicators
secmaster:indicator:export
Export emergency vulnerabilities
secmaster:emergencyVulnerability:export
Get incident details
secmaster:incident:get
Query alert rule template details
secmaster:alertRuleTemplate:get
Get field details
secmaster:dataclass:getField
Show vulnerabilities group info
secmaster:vulnerability:getGroup
Get workflow details
secmaster:workflow:get
Get alert details
secmaster:alert:get
Query the indicator list
secmaster:indicator:list
Query pipe details
secmaster:pipe:get
Get classifier details
secmaster:mapping:getClassifier
Get playbook details
Get pipe consumption
secmaster:pipe:getConsumption
Download the indicator template
secmaster:indicator:downloadTemplate
Get the monitor of playbook
secmaster:playbook:getMonitor
Export a playbook
secmaster:playbook:export
Query the dataclass details
Query alert rule details
secmaster:alertRule:get
Get mapper details
secmaster:mapping:getMapper
Get a wizard
secmaster:layout:getWizard
Get type details
secmaster:dataclass:getType
Get asset credential details
secmaster:connection:get
Get task details
secmaster:task:get
Show report
secmaster:report:get
Query a pipe index
secmaster:pipe:getIndex
Query playbook topology details
secmaster:playbook:getInstanceTopology
Show agency
secmaster:agency:get
Get indicator details
secmaster:indicator:get
Get mapping datasources
secmaster:mapping:getDatasource
Show resource statistics
secmaster:resource:getStatistics
Get the workflow instance topology
secmaster:workflow:getInstance
Get workspace details
secmaster:workspace:get
Get resource import template
secmaster:resource:getTemplate
Get workflow version details
secmaster:workflow:getVersion
Get a layout
Get playbook version details
secmaster:playbook:getVersion
Get dataspace details
secmaster:dataspace:get
Get a layout field.
secmaster:layout:getField
Show metric result
secmaster:metric:getResult
Query the alert list
secmaster:alert:list
Query alert rules
secmaster:alertRule:list
Get the playbook list
secmaster:playbook:list
Query the search condition list
secmaster:searchCondition:list
Query the pipe list
secmaster:pipe:list
List alert rule template metrics
secmaster:alertRuleTemplate:listMetrics
Query the approval list
secmaster:playbook:listApproves
export vulnerabilities groups
secmaster:vulnerability:exportGroup
List emergency vulnerabilities
secmaster:emergencyVulnerability:list
Query the mapper list
secmaster:mapping:listMappers
Search category
secmaster:catalogue:list
Query the type list
secmaster:dataclass:listTypes
List metric results
secmaster:metric:listResults
Query the playbook instance list
secmaster:playbook:listInstances
Query logs
secmaster:search:listLogs
Get layout field list
secmaster:layout:listFields
List vulnerabilities groups
secmaster:vulnerability:listGroups
Get the playbook version list
secmaster:playbook:listVersions
Get the incident type list
secmaster:incident:listTypes
Query mapping functions
secmaster:mapping:listFunctions
Query histograms
secmaster:search:listHistograms
Get layout type list
secmaster:layout:listBusinessTypes
Create batch orderAlerts
secmaster:alert:batchOrders
Query the workflow list
secmaster:workflow:list
Get the workflow version list
secmaster:workflow:listVersions
Query the playbook instance auditlog list
secmaster:playbook:getInstanceAuditlog
Query the task list
secmaster:task:list
List reports
secmaster:report:list
Get layout list
Query the indicator type list
secmaster:indicator:listTypes
Get dataclass list
Query the dataspace list
secmaster:dataspace:list
List alert rule templates
Query the mapping list
Query the field list
secmaster:dataclass:listFields
Get alert rule metrics
secmaster:alertRule:listMetrics
Get wizard list
secmaster:layout:listWizards
Query the incident list
Query the incident category list
secmaster:incident:listCategories
Query the dataObject relation list
secmaster:dataobject:listRelations
Query the alert category list
secmaster:alert:listCategories
Query the vulnerability type list
secmaster:vulnerability:listTypes
Query the asset credential list
secmaster:connection:list
List resources
secmaster:resource:list
Query the alert type list
secmaster:alert:listTypes
Search metric hits
secmaster:metric:listHits
Query the workspace list
secmaster:workspace:list
query tags of resource
secmaster:workspace:listTags
List cloud logs config
secmaster:collector:listConfig
secmaster:cloudLog:list
Query cloud logs resource
secmaster:cloudLog:listResourceConfig
List collector parser templates
secmaster:collectorParser:listTemplates
List collector parsers
Export collector parsers
secmaster:collectorParser:export
List collector connections
secmaster:collectorConnection:list
Get collector connection
secmaster:collectorConnection:get
List collector channel instances
secmaster:collectorChannel:listInstances
List collector channels
Get collector channel
secmaster:collectorChannel:get
List collector channel nodes
secmaster:collectorChannel:listNodes
List collector channel group
secmaster:collectorChannelGroup:list
List collector nodes
secmaster:collectorNode:list
List components configuration template
secmaster:component:listTemplates
List components configurations
secmaster:component:listConfigurations
Show component info
secmaster:component:get
List component info
List component history configuration info
secmaster:component:listConfigurationVersions
List component running node info
secmaster:component:listRunningNodes
List node info
secmaster:node:list
Get table consumption
secmaster:table:getConsumption
Export an analysis script
secmaster:analysisScript:export
Show collector parser
secmaster:collectorParser:get
Table 2 Write permissions supported
Permission
Action
Delete a workflow
secmaster:workflow:delete
Delete a pipe
secmaster:pipe:delete
Create a workspace
secmaster:workspace:create
Delete a mapping
secmaster:mapping:delete
Import resources
secmaster:resource:import
Create a wizard
secmaster:layout:createWizard
Update an incident
secmaster:incident:update
import playbook
secmaster:playbook:import
Create a playbook version
secmaster:playbook:createVersion
Approve a workflow version
secmaster:workflow:approveVersion
Delete a workflow version
secmaster:workflow:deleteVersion
Operate a playbook instance
secmaster:playbook:operateInstance
Bind an indicator type with layout
secmaster:indicator:bindLayout
Delete a layout field
secmaster:layout:deleteField
Delete pipe consumption
secmaster:pipe:deleteConsumption
Delete report
secmaster:report:delete
Create agency
secmaster:agency:create
Update wizards
secmaster:layout:updateWizard
Copy a mapping
secmaster:mapping:copy
Update the status of a mapping
secmaster:mapping:update
Approve a playbook
secmaster:playbook:approve
Create a search condition
secmaster:searchCondition:create
Update a workflow version
secmaster:workflow:updateVersion
Create an incident type
secmaster:incident:createType
Update a mapper
secmaster:mapping:updateMapper
Create alert rule
secmaster:alertRule:create
Update a dataclass
secmaster:dataclass:update
Update a pipe
secmaster:pipe:update
Create a layout
Enable or disable an incident type
secmaster:incident:enableType
Update a layout
Operate a workflow instance
secmaster:workflow:operateInstance
Update a layout field
secmaster:layout:updateField
Delete alert rule
secmaster:alertRule:delete
Update an alert
secmaster:alert:update
Delete an incident type
secmaster:incident:deleteType
Create an alert
secmaster:alert:create
Enable or disable an alert type
secmaster:alert:enableType
Delete an incident
Create a workflow version
secmaster:workflow:createVersion
Create a classifier
secmaster:mapping:createClassifier
Delete a mapper
secmaster:mapping:deleteMapper
Update report
secmaster:report:update
Execute an analysis
secmaster:search:createAnalysis
Update a workspace
secmaster:workspace:update
Update a search condition
secmaster:searchCondition:update
Delete a playbook
secmaster:playbook:delete
Create a task
secmaster:task:create
Create a dataclass
secmaster:dataclass:create
Update an alert type
secmaster:alert:updateType
Update a workflow
Delete a vulnerability type
secmaster:vulnerability:deleteType
Create a layout field
secmaster:layout:createField
Update an asset credential
secmaster:connection:update
Delete an alert type
secmaster:alert:deleteType
Create a mapper
secmaster:mapping:createMapper
Create a playbook
Set emergency vulnerability read status
secmaster:emergencyVulnerability:updateReadStatus
Verify a workflow version
secmaster:workflow:validate
Update a pipe index
secmaster:pipe:updateIndex
Create a workflow
Create report
secmaster:report:create
Create an alert type
secmaster:alert:createType
Update alert rules
secmaster:alertRule:update
Create a dataspace
secmaster:dataspace:create
Create pre-paid order
secmaster:subscription:createPrePaidOrder
Create pipe consumption
secmaster:pipe:createConsumption
Delete a workspace
secmaster:workspace:delete
Update a classifier
secmaster:mapping:updateClassifier
Simulate alert rule
secmaster:alertRule:createSimulation
Create a pipe
Delete post-paid order
secmaster:subscription:deletePostPaidOrder
Enable or disable a vulnerability type
secmaster:vulnerability:enableType
Update an incident type
secmaster:incident:updateType
Update indicator
secmaster:indicator:update
Bind a vulnerability type with a layout
secmaster:vulnerability:bindLayout
Delete a playbook version
secmaster:playbook:deleteVersion
Update a field
secmaster:dataclass:updateField
Delete a wizard
secmaster:layout:deleteWizard
Bind an alert type with a layout
secmaster:alert:bindLayout
Update a vulnerability type
secmaster:vulnerability:updateType
Delete an asset credential
secmaster:connection:delete
Update a category
secmaster:catalogue:update
Disable alert rule
secmaster:alertRule:disable
Create an incident
Create a field
secmaster:dataclass:createField
Delete a dataspace
secmaster:dataspace:delete
Delete field
secmaster:dataclass:deleteField
Create indicator
secmaster:indicator:create
Copy a playbook version
secmaster:playbook:copyVersion
Create dataObject relations
secmaster:dataobject:createRelation
Delete a search condition
secmaster:searchCondition:delete
Delete a classifier
secmaster:mapping:deleteClassifier
Update a playbook version
secmaster:playbook:updateVersion
Bind an incident type with a layout
secmaster:incident:bindLayout
Delete an alert
Delete a dataclass
Delete dataObject relations
secmaster:dataobject:deleteRelation
import indicator
secmaster:indicator:import
Create an asset credential
secmaster:connection:create
Update a playbook
Delete layouts
Update a task
secmaster:task:update
Transfer to template
secmaster:layout:createTemplate
Update a dataspace
secmaster:dataspace:update
Create post-paid order
secmaster:subscription:createPostPaidOrder
Create a vulnerability type
secmaster:vulnerability:createType
Delete indicator
secmaster:indicator:delete
Enable alert rule
secmaster:alertRule:enable
Update the debug result of a workflow version
secmaster:workflow:simulate
update tag
secmaster:workspace:updateTag
batch delete tags
secmaster:workspace:deleteTags
batch create tags
secmaster:workspace:createTags
Create cloud logs config
secmaster:collector:createConfig
secmaster:cloudLog:create
Delete cloud logs config
secmaster:cloudLog:delete
Create collector parsers
secmaster:collectorParser:create
Delete collector parser
secmaster:collectorParser:delete
Create collector connection
secmaster:collectorConnection:create
Update collector connection
secmaster:collectorConnection:update
Delete collector connection
secmaster:collectorConnection:delete
Create collector channel
secmaster:collectorChannel:create
Delete collector channel
secmaster:collectorChannel:delete
Update collector channel
secmaster:collectorChannel:update
Create collector channel operation
secmaster:collectorChannel:createOperation
Delete collector channel group
secmaster:collectorChannelGroup:delete
Update collector channel group
secmaster:collectorChannelGroup:update
Create collector channel group
secmaster:collectorChannelGroup:create
Update component configuration info
secmaster:component:updateConfigurations
Delete node info
secmaster:node:delete
Update node info
secmaster:node:update
Create table consumption
secmaster:table:createConsumption
Delete table consumption
secmaster:table:deleteConsumption
Import an analysis script
secmaster:analysisScript:import
