SecMaster Custom Policies
Custom policies can be created to supplement the system-defined policies of SecMaster. For the actions that can be added to custom policies, see SecMaster Permissions and Supported Actions.
Currently, the cloud service platform allows you to create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy . The following section shows examples of common SecMaster custom policies.
Example Custom Policies
- Example 1: Authorization for alert list search permission and permission execution analysis
1 2 3 4 5 6 7 8 9 10 11 12
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "secmaster:alert:list", "secmaster:search:createAnalysis" ] } ] }
- Example 2: Preventing users from modifying alert configurations
A deny policy must be used together with other policies. If the policies assigned to a user contain both Allow and Deny actions, the Deny actions take precedence over the Allow actions.
You can use the following method to create a custom policy that disallows users who have the SecMaster FullAccess policy assigned to modify alert configurations. Assign both SecMaster FullAccess and the custom policies to the group to which the user belongs. Then the user can perform all operations except modifying alert configurations on SecMaster. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "secmaster:alert:updateType" ] } ] }
- Example 3: Defining permissions for multiple services in a policy
A custom policy can contain the actions of multiple services that are of the global or project-level type. The following is an example policy containing actions of multiple services:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "secmaster:alert:get", "secmaster:alert:update" ] }, { "Effect": "Allow", "Action": [ "hss:vuls:set", "hss:vuls:list" ] } ] }
