Managing Check Plans
This topic describes how to manage check plans under Baseline Inspection.
Limitations and Constraints
- The default check plan can be enabled or disabled only. No changes on its compliance packs or execution time can be made.
- You can edit and delete custom check plans only.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose . On the displayed page, click the Security Standards tab. Then, click the Check Plan tab.
- On the Check Plan page, manage check plans.
Table 1 Check plan management Operation
Viewing a check plan
On the Check Plan tab, you can view the name, execution time, and compliance packs of a check plan.
Editing a custom check plan
- In the upper right corner of the check plan box, click Edit. The pane for editing the check plan is displayed on the right.
- Edit settings and click OK.
Disabling or enabling a check plan
Toggle on or off the status button in the box where the target check plan is located.
Deleting a custom check plan
- In the upper right corner of the check plan box, click Delete.
