Updated on 2025-11-11 GMT+08:00
Managing Compliance Packs
This topic describes how to manage compliance packs. You can view a compliance pack, add a custom compliance pack, import a compliance pack, and export a compliance pack. You can also edit, enable, disable, and delete a compliance pack. For details, see Editing, Enabling, Disabling, or Deleting a Compliance Pack.
  • Viewing compliance packs: Both built-in and custom compliance packs can be viewed.
  • Adding a custom compliance pack: Only custom compliance packs can be added.
  • Importing a compliance pack: Only custom compliance packs can be imported.
  • Exporting compliance packs: Both built-in and custom compliance packs can be exported.
  • Editing a compliance pack: Only custom compliance packs can be edited. Built-in compliance packs cannot be edited.
  • Enabling and disabling compliance packs: Both built-in and custom compliance packs can be enabled and disabled.
  • Deleting a compliance pack: Only custom compliance packs can be deleted. Built-in compliance packs cannot be deleted.
Limitations and Constraints
  • When you import a compliance pack, note the following restrictions:
    • Only .xlsx files can be imported.
    • Only one file can be imported at a time. Maximum file size: 100 records.
  • Built-in compliance packs cannot be edited or deleted.
  • If there are workspace agencies, the compliance packs displayed on the Risk Prevention > Baseline Inspection page of an agency view are the same as those configured in the primary workspace. The primary workspace is the workspace you associate with the workspace agency when you create an agency. For details, see Step 1: Create an Agency View.
  • You can only view, enable, disable, and export the OS Configuration Baseline, Common Weak Password Detection, and Password Complexity Policy Detection compliance packs. They cannot be imported, edited, or deleted.
Viewing Compliance Packs
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Compliance Pack tab.
  5. View details about compliance packs. For details about the parameters, see Table 1.
    Table 1 Parameters for compliance packs
    Total Compliance Packs
    Total number of existing compliance packs are organized, as well as the number of compliance packs by their statuses.
    • Total compliance packs
    • Number of enabled compliance packs
    • Number of disabled compliance packs
    Built-in Compliance Packs
    The number of compliance packs preconfigured in SecMaster.
    Custom Compliance Packs
    The number of compliance packs you add.
    Compliance packs and their details
    All compliance packs and their basic information.
    • In the compliance pack list, you can view the type, status, and number of check items of a compliance pack. You can also enable, disable, and delete a compliance pack.
    • To display certain columns only, click the setting button in the upper right corner of the compliance pack list and complete the settings (for example, whether to wrap lines and whether to fix the operation column).
    • To view details about a compliance pack, click its name to go to its details page.
      On the compliance pack details page, you can view its version, description, and check items.
Creating a Custom Compliance Pack
  5. In the upper left corner above the compliance list, click Add
  6. On the displayed page, configure basic information about the compliance pack.
    Table 2 Basic information
    Compliance Pack
    Enter a compliance pack name. It must meet the following requirements:
    • The package name can contain only letters, digits, underscores (_), periods (.), and hyphens (-).
    • Length: 1 to 256 characters
    Provide a description of the compliance pack. The length cannot exceed 4,096 characters.
    (Optional) Advanced Settings
    Version
    Set the compliance pack version. Example: v1.0
    The configuration requirements are as follows:
    • Only letters, digits, underscores (_), periods (.), and hyphens (-) are allowed.
    • The value can contain 1 to 64 characters.
    Classify
    Enter the category the compliance pack belongs to.
    Compliance pack categories can be international standards, laws and regulations, industry standards, and financial standards.
    Domain
    Enter the domain the compliance pack belongs to. Examples of domains: information security, privacy protection, cyber security, and data security.
    Owner
    Specify the people in charge of the compliance pack.
    Applicable Region
    Enter the region where the compliance pack is used. Example: Global, Asia Pacific, and more.
  7. Click Next to go to the configuration page.
  8. On the displayed page, complete other parameters of the compliance pack.
    1. In the navigation pane on the left, click . In the displayed text box, enter the node name and click OK.
      • Adding a subnode: To add a level-2 or level-3 node, hover over the node name and click the Create button. In the text box displayed, enter the node name and press Enter.
      • Editing or deleting a node: To edit or delete a node, hover over the node name and click the Edit or Delete button.
    2. Select the name of an added node (minimum level. For example, if a level-3 node is added, select the level-3 node name). In all check items displayed on the right, select the check items you want to associate.
  9. Click Next to enter the confirmation page.
  10. Confirm the settings and click OK.
  11. Check the compliance pack you added. You can enable, disable, edit, and delete the compliance packs you add.
Importing a Compliance Pack
  5. In the upper left corner above the compliance pack list, click Import.
  6. In the dialog box displayed, click Download Template and complete the template.
  7. In the displayed dialog box, click Add File and upload the completed template file.
  8. Click Import.
  9. Check the compliance pack you imported. You can enable, disable, edit, and delete the compliance packs you import.
Exporting a Compliance Pack
  5. Select the target compliance pack and click Export in the upper left corner of the compliance pack list.
  6. In the displayed dialog box, select the format and data columns you want.
  7. Click Export.
  5. In the compliance pack list, edit, enable, disable, or delete a compliance pack.
    Table 3 Enabling, disabling, or deleting a compliance pack
    Operation
    Editing a custom compliance pack
    1. Click the name of the target compliance package.
    2. Edit basic information: On the compliance pack details page, click next to the name and description of the compliance pack, edit the information, and click to save the modification.
    3. Edit the compliance pack content: Locate the target compliance pack and click Edit. On the displayed page, edit the compliance pack node or select the check items to be associated, and click OK.
    Disabling a compliance pack
    1. Locate the row that contains the target compliance pack and click Disable in the Operation column.
    2. In the displayed dialog box, click OK.
    3. If a compliance pack is disabled, its status will change to Disabled on the compliance pack page.
    Enabling a compliance pack
    1. Locate the row that contains the target compliance pack and click Enable in the Operation column.
    3. If a compliance pack is enabled, its status will change to Enabled on the compliance pack page.
    Deleting a custom compliance pack
    Only Disabled custom compliance packs can be deleted.
    1. Locate the target custom compliance pack and click Delete in the Operation column.
    2. In the displayed dialog box, confirm the deletion object, enter DELETE, and click OK.
