Creating and Editing a Parser
SecMaster provides some preconfigured parsers for quick use. You can use the parsers you need.
Type |
Scenario |
Quick access |
The source data can be directly transmitted without being processed. |
Template |
When you need to clear data sources or process fields, you can select a template based on the application scenario and create a parser. |
Custom |
You can create custom parsers and configure parsing rules to meet your needs, such as clearing data sources, processing fields, and more. |
This topic describes how to add and edit a log parser. With a log parser, you can convert the log format in a codeless manner. In SecMaster, you can configure log parsers in two ways:
- Using a template: SecMaster provides some log parser (rule) templates. You can use them to configure parsers quickly.
- Creating custom parsers: If the log parser (rule) templates SecMaster provides for you cannot meet your log conversion requirements, you can create custom log parsers (rules).
Creating a Parser
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose Parsers tab. . Then, select the
- Customize a parser or create a parser from a template.
- Customizing a parser
- On the Parsers tab page, click Add.
- On the Parsers tab page, set parameters.
Table 2 Parameters for adding a parser Parameter
Basic Information
Parser Name
Set the parser name.
Enter the parser description.
Rules
Set the parsing rule of the parser. Perform the following steps:
- Click Add and select a rule type.
- Parsing rule: Select the parsing rule of the parser. For details about the parameters, see Parser Rules.
- Conditional control: Select the conditions for the parser. You can select If, Else, or Else if.
- Set parameters based on the selected rule.
- After the setting is complete, click OK in the lower right corner of the page to confirm the setting.
- Creating a parser from a template
- On the Parsers page, click the Templates tab.
- On the displayed page, locate the row that contains the target template, click Created by Template in the Operation column.
Table 3 Parameters for adding a parser Parameter
Basic Information
Parser Name
Parser name, which is automatically generated by the system based on the template and can be changed.
Parser description, which is automatically generated by the system based on the template and can be modified.
Rule list
Parsing rule, which is automatically generated by the system based on the template and can be modified.
To add a rule, click Add, select a rule type, and set parameters based on the selected rule.
Editing a Parser
- Click
- On the Parsers tab, locate the row containing your desired parser and click Edit in the Operation column.
- In the Edit Parser dialog box, edit the parser information.
Table 4 Editing a parser Parameter
Basic Information
Parser Name
Rule list
- Conditional control: Select the conditional control principle of the parser.
Related Operations
You can view parsers, as well as import, export, and delete a parser. For details, see Managing Parsers.
