Updated on 2025-11-11 GMT+08:00
Connector Rules
Source Connectors
SecMaster provides a wide range of source connectors for you to collect security data from your security products.
Table 1 Source connector types
Connector Type
Logstash In Use
TCP
tcp
This collector is used to receive TCP logs. For details about the configuration rules, see Table 2.
UDP
udp
This collector is used to receive UDP logs. For details about the configuration rules, see Table 3.
OBS
obs
This collector is used to obtain log data from an OBS bucket. For details about the configuration rules, see Table 4.
Kafka
kafka
This collector is used to obtain Kafka network log data. For details about the configuration rules, see Table 5.
pipe
This collector is used to transfer SecMaster data to you. For details about the configuration rules, see Table 6.
Elasticsearch
elasticsearch
This collector is used to read data from the Elasticsearch cluster. For details about the configuration rules, see Table 7.
Table 2 TCP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
Name of the connector with custom sources. It must meet the following requirements:
  • The name can contain 5 to 128 characters.
  • The name must be unique in the workspace and cannot be the same as the name of any other connector in the workspace.
description
string
Yes
Description of the custom connector. It must meet the following requirements:
  • The name can contain up to 256 characters.
Port
port
number
1025
Yes
Port for the collection node.
Port range: 1025 to 65535
The port for each connector must be unique.
Codec
codec
string
plain
Yes
Encoding format.
  • Plain: Reads the raw content.
  • Json: Processes the content in JSON format.
SSL_enable
ssl_enable
boolean
false
No
Whether to enable SSL authentication.
SSL certificate
ssl_cert
file
null
No
If SSL_enable is set to Yes, you need to upload a .cert certificate.
SSL key
ssl_key
file
No
If SSL_enable is set to Yes, you need to upload an SSL certificate key file.
SSL key.
ssl_key_passphrase
string
No
If SSL_enable is set to Yes, you need to enter the SSL certificate key.
Table 3 UDP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
Name of the custom connector. It must meet the following requirements:
description
string
Yes
Port
port
number
1025
Yes
The port ranges from 1025 to 65535. The port for each connector must be unique.
Codec
codec
string
plain
Yes
Decoding type
Type
type
string
udp
No
Packet label, which is used for subsequent processing. One data collection channel maps to multiple data connections. You are advised to add different packet labels to each data connection to distinguish packets of different data connections.
Queue_size
queue_size
number
1000000
No
Queue size.
Receive_buffer_bytes
receive_buffer_bytes
number
1000000
No
Number of bytes in the receiving buffer. Retain the default value.
Buffer_size
buffer_size
number
1000000
No
Buffer size. Retain the default value.
Workers
workers
number
No
Number of worker threads. Retain the default value.
Table 4 OBS connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Region
Region
string
Yes
Region of the workspace where the data source is located.
Bucket
bucket
string
demo-obs-sec-mrd-datas
Yes
Bucket name, which is the name of the bucket where the data source is located.
Endpoint
Endpoint
string
Yes
Endpoint address. Note that "https" must be added. You can obtain the endpoint address from the bucket details.
AK
ak
string
No
AK
SK
sk
string
No
SK
Prefix
prefix
string
/test
No
Prefix of the folder where logs are read. Enter the folder prefix corresponding to the storage path of the data source in the bucket.
Cache folder
temporary_directory
string
/temp
No
Cache folder for reading logs. When SecMaster log data is transferred out, the data needs to be cached in the cache folder first. The data is transferred out after the data volume reaches a certain threshold. You need to create the /opt/cloud/logstash/myobs directory on the ECS and use the directory as the cache folder path.
Packet label
type
string
No
Memory path
sincedb_path
string
/opt/cloud/logstash/pipeline/file_name
No
Log read position. This parameter is used to prevent full-text traversal caused by restart. You are advised to retain the default value.
Table 5 Kafka connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Bootstrap_servers
bootstrap_servers
string
Yes
Kafka service address.
Topics
topics
array
logstash
Yes
Topics. Multiple topics can be consumed at the same time.
Consumer threads
consumer_threads
number
Yes
Consumer threads
Group_id
group_id
string
No
Consumer group ID.
Auto offset reset
auto_offset_reset
string
latest
No
Offset reset:
  • Earliest: Read the earliest message.
  • Latest: Read the latest messages.
Security_protocol
security_protocol
string
SASL_SSL
No
Security protocol.
  • PLAINTEXT: plaintext transmission scenario
  • SSL: SSL transmission scenario
  • SASL_PLAINTEXT: SASL plaintext transmission scenario
  • SASL_SSL: SASL ciphertext transmission scenario
Sasl_jaas_config
sasl_jaas_config
string
No
SASL connection configuration.
Is_pw_encrypted
is_pw_encrypted
string
false
No
Whether to encrypt the value.
Sasl_mechanism
sasl_mechanism
string
PLAIN
No
SASL mechanism.
Set sasl_jaas_config based on the Kafka specifications. Example:
  • Plaintext connection configuration
    org.apache.kafka.common.security.plain.PlainLoginModule required username='kafka user'password='kafka password';
  • Ciphertext connection configuration
    org.apache.kafka.common.security.scram.ScramLoginModule required username='kafka user name'password='kafka password';
Table 6 Pipe connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
Name of the custom connector. The name must meet the following requirements:
description
string
Yes
Type
type
string
Tenant
Yes
Type
StreamTable
pipe_id
string
Yes
Select a stream table from the drop-down list. This table stores the source data you want to transfer out from SecMaster.
Pipeline
pipeId
string
Yes
Pipeline ID
domain_name
domain_name
string
domain_name
Yes
Domain name of the user
User_name
user_name
string
user_name
Yes
Username of the user
Password
user_password
string
Yes
Subscription type
subscription_type
string
true
No
Subscription type
  • Shared: shared mode
  • Exclusive: exclusive mode
  • Failover: disaster recovery mode
Subscription Start
subscription_initial_position
string
true
No
Subscription Start
Table 7 Elasticsearch connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Hosts
hosts
array
Yes
Address of the host where the data source is located.
Index
index
string
Yes
Index name.
Query
query
string
Yes
Retrieval statement for reading data.
User
user
string
Yes
Username for logging in to Elasticsearch.
User_password
user_password
string
Yes
Password for logging in to Elasticsearch.
Size
size
number
20
Yes
Queries
Scroll
scroll
string
5m
Yes
Volume
Docinfo
docinfo
boolean
Yes
Yes
Document
Is_pw_encrypted
is_pw_encrypted
boolean
Yes
Yes
Whether to enable encryption.
Ssl
ssl
boolean
Yes
No
Whether to enable SSL.
Ca_file
ca_file
file
No
Certificate file.
SsL_certificate_verification
ssl_certificate_verification
boolean
Yes
No
Whether to enable SSL certificate verification.
Destination Connectors
SecMaster provides a wide range of destination connectors for you to collect security data from your security products.
Table 8 Destination connectors
Connector Type
In-use Logstash
TCP
tcp
This collector is used to send TCP logs. For details about the configuration rules, see Table 9.
UDP
udp
This collector is used to send UDP logs. For details about the configuration rules, see Table 10.
Kafka
kafka
This collector is used to write logs to Kafka message queues. For details about the configuration rules, see Table 11.
OBS
obs
This collector is used to write logs to OBS buckets. For details about the configuration rules, see Table 12.
SecMaster pipeline
pipe
This collector is used to write logs to the SecMaster pipeline. For details about the configuration rules, see Table 13.
Table 9 TCP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Port
port
number
1025
Yes
Port
Codec
codec
string
plain
Yes
Decoding type, which can be Json_lines or Plain.
  • Plain: Reads the original content.
  • Json_lines: Processes the content in JSON format.
Hosts
host
string
192.168.0.66
Yes
Host address
Note: The network between the host and the node is normal.
Ssl_enable
ssl_enable
boolean
false
No
SSL certificate
ssl_cert
file
No
SSL key
ssl_key
file
No
SSL key
ssl_key_passphrase
string
No
Table 10 UDP connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Hosts
host
string
Yes
Host IP address.
Port
port
number
1025
Yes
Port
Decoding type
codec
string
json_lines
Yes
Retry count
retry_count
number
3
No
Time of retry attempts
Retry backoff (ms)
retry_backoff_ms
number
200
No
Retry backoff (ms)
Table 11 Kafka connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Service address
bootstrap_servers
string
Yes
Service address, for example, 192.168.21.21:9092,192.168.21.24:9999.
Topics
topic_id
string
logstash
Yes
Topics
Decoding type
codec
string
plain
Yes
Decoding type, which can be Json or Plain.
Maximum length of the request
max_request_size
number
10485760
Yes
Security_protocol
security_protocol
string
PLAINTEXT
No
Security protocol
sasl_jaas_config
string
No
Encrypted
is_pw_encrypted
string
true
No
Encrypted
SASL mechanism
sasl_mechanism
string
PLAIN
No
sasl_mechanism
Set sasl_jaas_config based on the Kafka specifications. The following is an example:
Table 12 OBS connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Title
title
string
Yes
description
string
Yes
Region
Region
string
Yes
Region
Bucket
bucket
string
Yes
Bucket name
Endpoint
Endpoint
string
Yes
Endpoint
Cache folder
temporary_directory
string
/temp/logstash/
Yes
Cache path
Encoding type
codec
string
plain
No
Encoding format: plain or JSON
AK
ak
string
No
AK
SK
sk
string
No
SK
Prefix
prefix
string
test
No
Path prefix.
Encoding format
encoding
string
gzip
No
Encoding format: gzip or pure file
Table 13 Pipe connector configuration rules
Rule
Logstash Settings
Type
Default Value
Mandatory
Type
type
string
Tenant
Yes
Type
Pipeline
pipeId
string
Yes
Pipeline
AK
ak
string
Yes
AK
This parameter is mandatory when the platform type is selected.
SK
sk
string
Yes
SK
domain_name
domain_name
string
domain_name
Yes
This parameter is mandatory when the tenant type is selected.
User_name
user_name
string
user_name
Yes
Password
user_password
string
Yes
Password of the user
Compression type
compression_type
string
NONE
No
Packet compression type
Block if the queue is full
block_if_queue_full
boolean
true
No
Whether to block the access if the queue is full.
Enable batch processing
enable_batching
boolean
true
No
Whether to enable batch processing.
