Partitioning a Disk
To keep collectors healthy for you to collect security data, there are some limitations and constraints.
- Only non-administrator users can be used for installing isap-agent.
 - Make sure the /opt/cloud directory where you install isap-agent and use the collector has at least 100 GB of free disk space.
When you install the isap-agent in the /opt directory on an ECS, if the message shown in Figure 1 is displayed, the space of the /opt directory is insufficient.
To ensure at least 100 GB space is available in the directory where the component controller isap-agent is installed, you may need to partition the disk.
The procedure is as follows:
- Apply for and attach a disk.
 - Click
 in the upper left corner and select the region and project. - In the upper left corner of the page, click
 and choose . In the ECS list, click the name of the ECS where isap-agent is installed to go to the ECS details page. - Click the Disks tab. On the displayed page, click Add Disk.
 - On the displayed page, apply for a disk with Disk Specifications set to 100 GiB.
For details, see Elastic Volume Service User Guide.
 - After the disk is successfully attached, you can view the attached disk on the Disks tab for the ECS.
After a data disk is attached to a server, you must log in to the server and initialize the disk before you can use the disk.
 - Partition the disk.
- Log in to the node where isap-agent is installed and run the following command to check the disk usage:
 - Run the following command to partition the disk:
sh /opt/cloud/isap-agent/action/agent_controller_linux.sh partition
If the following information is displayed, the disk is partitioned successfully.
Figure 3 Disk partitions
 - Reinstall the component controller isap-agent. For details, see Managing Nodes.
