One-Click Blocking or Unblocking
One-Click Blocking: You can configure a one-click blocking policy to block access from malicious IP addresses or unauthorized IAM users.
One-Click Unblocking: You can unblock IP addresses or users that were blocked by one-click blocking policies with just a single click. This action only applies to alerts for which one-click blocking was successfully executed.
Security policies are used to quickly prevent attacks from malicious IP addresses. You can select a block type based on the alert source to block attackers.
This topic describes how to block or unblock attack sources quickly.
Limitations and Constraints
- In a workspace you have, you can add up to 300 security policies that support block aging, and a maximum of 2,500 security policies in total. Limits on blocked objects you can add are as follows:
- For a policy to be delivered to WAF, each time a maximum of 500 IP addresses can be added as blocked objects by each account.
 - For a policy to be delivered to VPC, every minute a maximum of 500 IP addresses can be added once as blocked objects by each account.
 - If an IP address is added to the blacklist, VPC or WAF will block requests from that IP address without checking whether the requests are malicious.
 - To ensure system stability, a maximum of five security policy tasks can be executed at the same time. If there are already five ongoing tasks, no more security policies can be added, retried, or edited.
 - After a security policy is added, its blocked object type and blocked objects, such as IP addresses and IP address ranges, cannot be modified.
 - After a security policy is added, its policy object, policy type, object type, and selected operation connections cannot be modified.
- If an IP address is configured in both a blacklist and whitelist of the same cloud service, the blacklist works.
One-Click Blocking
 - Click
 in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
 - In the navigation pane on the left, choose .
 - In the alert list, locate the row that contains the target alert and choose Operation > One-Click Block in the Operation column. The One-Click Block panel is displayed on the right.
You can also go to the details page of the target alert and click One-Click Block on the top of the page.
 - On the displayed page, configure the blocking policy.
Table 1 Parameters for a one-click blocking policy Parameter
Policy Type
Type of the policy. You can select Block or Allow.
- If Block is selected, the access from the policy object will be denied.
 - Allow: The access from the policy object will be allowed.
Object Type
If Policy Type is set to Block, Object Type can be set to IP, Account, or Domain name.
If Policy Type is set to Allow, Object Type can be set to IP or Domain name.
Select an object type based on your needs.
- If IP is selected, the operation object of the policy is an IP address or IP address range.
 - If Domain name is selected, the operation object of the policy is a domain name.
 - If Account is selected, the policy is applied to a cloud service account (IAM user).
Policy Object
Enter one or more policy objects.
- If Object Type is set to IP, enter IP addresses or IP address ranges. Enter one or more IP addresses or IP address ranges and separate them with commas (,).
Example: IPv4: 192.168.0.0 or 192.168.0.0/12; IPv6: 0:0:0:0:0:0:0:0 or 0:0:0:0:0:0:0:0/128.
 - If Object Type is set to Domain name, enter domain names. Enter one or more domain names. If there are multiple domain names, separate them with commas (,). Enter a maximum of 63 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
 - If Policy type is set to Block and Object Type is set to Account, set Policy Object to the cloud service account (IAM user). Enter one or more cloud service accounts (IAM usernames). If there are multiple cloud service accounts (IAM usernames), separate them with commas (,).
Policy Application Scope
Select Current region and enterprise project or All regions and enterprise projects based on your needs.
Operation Connection
Asset connections associated with the emergency policy process. Select the operation connection of the policy based on your needs.
- If Policy Type is set to Block and Object Type is set to IP, you can select CFW, VPC, and WAF operation connections.
 - If Policy Type is set to Block and Object Type is set to Account, you can select IAM operation connections.
 - If Policy Type is set to Block and Object Type is set to Domain name, you can select CFW operation connections.
 - If Policy Type is set to Allow and Object Type is set to IP, you can select WAF operation connections.
 - If Policy Type is set to Allow and Object Type is set to Domain name, you can select CFW operation connections.
Auto Expiration
Auto expiration configured for the policy.
- If you select Yes, set the policy expiration time.
 - If you select No, the policy is always valid.
Tag (Optional)
Tag of the custom emergency policy.
Policy Description (Optional)
Description of the custom policy.
 - Click OK.
The One-Click Unblocking operation can be performed only on alerts for which the One-Click Blocking operation has been delivered and is successfully executed.
 - Click
 - In the alert list, locate the row that contains the target alert, click More > One-Click Unblock in the Operation column.
You can also go to the details page of the target alert and click One-Click Unblock in the upper right corner of the page.
 - In the displayed dialog box, enter the reason and click OK.
