Which Commands Are Commonly Used for the Component Controller?
Here are some commands you may need to troubleshoot the installation failure of the component controller isap-agent.
- Restart
sh /opt/cloud/isap-agent/action/agent_controller_linux.sh restart
Note: This command will stop and then restart the isap-agent process. You can use this command to restart isap-agent if isap-agent fails start or the process does not exist due to a node fault.
- Start
sh /opt/cloud/isap-agent/action/agent_controller_linux.sh start
Note: You can use this command to start isap-agent if isap-agent breaks down but the automatic startup time for disaster recovery does not arrive.
- Stop
sh /opt/cloud/isap-agent/action/agent_controller_linux.sh stop
You can use this command to stop isap-agent. This command will clear the scheduled automatic startup check settings to stop the isap-agent process.
- Checking processes
You can use this command to check whether isap-agent is installed on the current host.
- Checking logs
tail -100f /opt/cloud/isap-agent/log/run.log
You can use this command to query the latest 100 lines of logs of the isap-agent service to locate exceptions.
- Disk partitions
sh /opt/cloud/isap-agent/action/agent_controller_linux.sh partition
When you install the collector on a node, you can use this command to partition disks you attach to the node.
