Configuring the Asset Subscription
SecMaster can synchronize asset information only in the workspace where asset subscription is enabled. After your subscription, SecMaster automatically updates resource information every night.
This section describes how to make a subscription to resources.
- Only cloud resources can be subscribed to and synchronized to SecMaster. Subscribing to resource information to multiple workspaces in a region is not recommended.
Limitations and Constraints
Only cloud resources are supported for asset subscription and synchronization.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose Resource Manager > Resource Manager.
Figure 1 Resource Manager
- On the Resource Manager page, click Asset Subscription in the upper right corner.
- On the Asset Subscription page sliding out from the right, locate the row that contains the region where the target resource is located, and enable subscription.
- Click OK.
