Importing and Exporting Incidents
This section describes how to import and export incidents.
- Importing incidents: You can batch import incidents using a list.
- Exporting incidents: You can export an incident list to a local PC to view incident information or share incident information with your team.
Limitations and Constraints
- Only files in .xlsx can be imported. Each time you can import a file no larger than 5 MB with a maximum of 100 records.
- A maximum of 9,999 incident records can be exported.
Importing Incidents
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose .
- On the Incidents page, click Import in the upper left corner above the incident list.
- In the displayed Import dialog box, click Download Template to download a template, and fill in the downloaded template according to the requirements.
- After the template is filled, click Add File in the Import Incident dialog box and select the Excel file you want to import.
- Click OK. After the import is complete, you can check imported incidents. Path: In the navigation pane on the left, choose .
Exporting Incidents
- Click
- On the Incidents page, select the incidents to be exported and click
in the upper right corner of the list. The Export dialog box is displayed.
- In the Export dialog box, set parameters.
Table 1 Exporting incidents Parameter
Format
By default, the incident list is exported into an Excel.
Columns
Select the parameters to be exported.
- Click OK.
The system automatically downloads the Excel to your local PC.
