Applying for SecMaster
You can apply for the SecMaster service based on your service requirements.
Applying for SecMaster: You can apply for SecMaster professional edition on demand. This section describes how to apply for SecMaster professional edition.
Applying for a Pay-per-Use Value-added Package: Based on the professional edition, SecMaster also provides value-added feature Large Screen. You can apply for this feature separately. This topic describes how to apply for a value-added package.
Limitations and Constraints
- The value-added package is an additional feature based on the professional edition. To use the value-added package, apply for the professional edition first.
- Click
in the upper part of the page and choose Security > SecMaster.
- Click Buy SecMaster.
- (Optional) You need to complete access authorization first time you apply for the service. On the Access Authorization slide-out panel displayed, select Agree and click OK.
- On the page for applying for SecMaster, configure parameters.
Table 1 Parameters for applying for the professional edition Parameter
Billing Mode
Select Pay-per-use. In this mode, you are billed by the hour. From the time when the service is enabled to the time when the service is canceled, you are billed for the actual duration by the hour.
Region
Select your region.
Edition
Select Professional.
Quota
The number of ECSs you want to protect.
The quota must be greater than or equal to the total number of ECSs within your account. This value cannot be changed to a smaller one after the application is completed.
NOTE:- The maximum quota is 10,000.
- If some of your ECSs are not protected by SecMaster, threats to them cannot be detected in a timely manner, which may result in security risks, such as data leakage. To prevent this, increase the quota whenever your server quantity increases.
Value-added Package
You can enable Large Screen if needed.
- Large Screen: There are always such scenarios as presentation, reporting, or real-time monitoring where you need to present the analysis results of SecMaster on big screens to achieve better demonstration effect. Now, SecMaster Large Screen is a good choice for you to display the service console on bigger screens for a better visual effect. All situations can be observed with one screen.
To enable this function, toggle on the button next to Large Screen.
You can apply for a value-added package along with SecMaster professional edition or apply for it later. For details, see Applying for a Pay-per-Use Value-added Package.
- Confirm the product details and click Next.
- After confirming that the order details are correct, read the SecMaster Disclaimer, select "I have read and agree to the SecMaster Disclaimer", and click Pay Now.
- On the payment page, select a payment method and complete the application.
- Click
- In the navigation pane on the left, choose Purchased Resources. On the page that is displayed, click Buy Value-added Package in the upper right corner.
Table 2 Parameters for applying for a value-added package Parameter
Billing Mode
Select Pay-per-use.
Region
Select your region.
Configuration
Details about SecMaster edition you are using are displayed.
Large Screen
Toggle on the
button next to Large Screen if you need to apply for the large screen function. (Enabled:
