On this page
Viewing Component Details
Updated on 2024-10-29 GMT+08:00
This topic describes how to view component details.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Settings > Components. Then, select the Components tab.
  5. On the Components page, view the component details.
    • Running Node
      Click the Running Node in the upper right corner of a component. The running node information of the component is displayed on the right.
    • View Settings
      Click View Settings in the upper right corner of the component to be viewed. The configuration details about the component are displayed on the right.
    • Edit Settings
      1. Click Edit Settings in the upper right corner of the component to be viewed. The Configuration Management panel of the component is displayed on the right.
      2. In the Node Configuration area, edit the node configuration information.
        • Adding a node: Click Add in the upper left corner of the node list. In the Add Node dialog box displayed, select a node and click OK.
        • Editing node parameters: Click next to the node name to expand the node configuration information and edit the node parameters.
        • Running parameters: Locate the row that contains the target node, click Run Parameter in the Operation column.
        • Removing a node: Locate the row that contains the target node and click Removed in the Operation column.
        • Batch deletion: Select the nodes you want to remove and click Batch Remove in the upper left corner of the list.
        • Viewing historical versions: Click Historical Version in the lower right corner of the panel.
      3. Click Save and Apply in the lower right corner of the page.
