Updated on 2025-06-26 GMT+08:00
Managing Nodes and Components
Viewing Node Details
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Settings > Components.
  5. On the Nodes tab, view the details about nodes.
    If there are many nodes displayed, use filters to search for a specific one.
    Table 1 Collection node parameters
    Node Name/ID
    Name or ID of a node
    Health Status
    Node health status
    Region
    Region where the node is located
    IP Address
    Node IP address
    CPU Usage
    CPU usage of the node
    Memory Usage
    Memory usage of the node
    Disk Usage
    Node disk usage
    Network Speed
    Network rate of a node
    Label
    Label information of a node
    Heartbeat Expiration Mark
    Indicates whether the node is disconnected due to heartbeat expiration.
    If no heartbeat message is sent within 15 minutes, the node is marked as Disconnected.
  6. To view details about a node, click the node name.
Deregistering a Node
  5. On the Nodes tab, locate the row that contains the target node and click Deregister in the Operation column.
  6. In the displayed dialog box, click OK.
    Only the node is deregistered. The ECS and endpoint interface resources are not deleted. If you no longer need the data collection function, you need to manually release those resources.
Viewing Component Details
  4. In the navigation pane on the left, choose Settings > Components. Then, select the Components tab.
  5. On the Components page, view the component details.
    • Running Node
      Click Running Node in the upper right corner of a component. The running node information of the component is displayed on the right.
    • View Settings
      Click View Settings in the upper right corner of the component to be viewed. The configuration details about the component are displayed on the right.
    • Edit Settings
      1. Click Edit Settings in the upper right corner of the component to be viewed. The Configuration Management panel of the component is displayed on the right.
      2. In the Node Configuration area, edit the node configuration information.
        • Adding a node: Click Add in the upper left corner of the node list. In the Add Node dialog box displayed, select a node and click OK.
        • Editing node parameters: Click next to the node name to expand the node configuration information and edit the node parameters.
        • Running parameters: Locate the row that contains the target node, click Run Parameter in the Operation column.
        • Removing a node: Locate the row that contains the target node and click Removed in the Operation column.
        • Batch deletion: Select the nodes you want to remove and click Batch Remove in the upper left corner of the list.
        • Viewing historical versions: Click Historical Version in the lower right corner of the panel.
      3. Click Save and Apply in the lower right corner of the page.
