Overview
You can use SecMaster to collect security logs on and off the cloud, as well as transfer security logs from SecMaster to a third-party system and product.
       Scenario  |
       Operation Guide  |
       Integrating logs of cloud services into SecMaster  |
       For details, see Enabling Log Access. You can enable log integration for many cloud services all at once.  |
       Integrating security logs from third parties (non-Huawei Cloud) into SecMaster  |
       Security logs of third parties are integrated by data collection. This section describes the data collection function.  |
       Transferring logs from SecMaster to a third-party system or product  |
       The procedure is the same as that for integrating logs from a third-party (non-Huawei Cloud) system into SecMaster. Major differences are as follows:
  Data Collection Principles
The basic principle of data collection is as follows: SecMaster uses a component controller (isap-agent) that is installed on your ECSs to manage the collection component Logstash, and Logstash transfer security data in your organization or between you and SecMaster.
  Basic Concepts
- Collector: custom Logstash. A collector node is a custom combination of Logstash+ component controller (isap-agent).
 - Node: If you install SecMaster component controller isap-agent on an ECS, the ECS is called a node. You need to deliver data collection engine Logstash to managed nodes on the Components page.
 - Component: A component is a custom Logstash that works as a data aggregation engine to receive and send security log data.
 - Connector: A connector is a basic element for Logstash. It defines the way Logstash receives source data and the standards it follows during the process. Each connector has a source end and a destination end. Source ends and destination ends are used for data inputs and outputs, respectively. The SecMaster pipeline is used for log data transmission between SecMaster and your devices.
 - Parser: A parser is a basic element for configuring custom Logstash. Parsers mainly work as filters in Logstash. SecMaster preconfigures varied types of filters and provides them as parsers. In just a few clicks on the SecMaster console, you can use parsers to generate native scripts to set complex filters for Logstash. In doing this, you can convert raw logs into the format you need.
 - Collection channel: A collection channel is equivalent to a Logstash pipeline. Multiple pipelines can be configured in Logstash. Each pipeline consists of the input, filter, and output parts. Pipelines work independently and do not affect each other. You can deploy a pipeline for multiple nodes. A pipeline is considered one collection channel no matter how many nodes it is configured for.
Limitations and Constraints
- Currently, the data collection component controller can run on Linux ECSs running the x86 or Arm architecture.
- You have purchased an ECS or have an available ECS for installing the log collector.
 - You have purchased a data disk and attached it to the ECS. The ECS has enough space to run the log collector.
 - You have obtained a non-administrator IAM account to log in to SecMaster as a tenant.
 - You have configured network connection to connect the tenant VPC to SecMaster.
Collector Specifications
The following table describes the specifications of the ECSs that are selected as nodes in collection management.
        vCPUs  |
        Memory  |
        System Disk  |
        Data Disk  |
        Referenced Processing Capability  |
        4 vCPUs  |
        8 GB  |
        50 GB  |
        100 GB  |
        2,000 EPS @ 1 KB 4,000 EPS @ 500 B  |
        8 vCPUs  |
        16 GB  |
        50 GB  |
        100 GB  |
        5,000 EPS @ 1 KB 10,000 EPS @ 500 B  |
        16 vCPUs  |
        32 GB  |
        50 GB  |
        100 GB  |
        10,000 EPS @ 1 KB 20,000 EPS @ 500 B  |
        32 vCPUs  |
        64 GB  |
        50 GB  |
        100 GB  |
        20,000 EPS @ 1 KB 40,000 EPS @ 500 B  |
        64 vCPUs  |
        128 GB  |
        50 GB  |
        100 GB  |
        40,000 EPS @ 1 KB 80,000 EPS @ 500 B  |
Log Source Limit
You can add as many as log sources you need to the collectors as long as your cloud resources can accommodate those logs. You can scale cloud resources anytime to meet your needs.
