Directory Customization
You can customize directories on SecMaster. This section includes the following content:
Limitations and Constraints
- Built-in directories cannot be edited or deleted.
Viewing Existing Directories
 - Click
 in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
 - In the navigation tree on the left, choose .
 - In the directory list, view the directory details.
Table 1 Directory parameters Parameter
Level-1 Directory
Name of the level-1 directory to which the directory belongs
Level-2 Directory
Name of the level-2 directory to which the directory belongs
Status
Type of the directory.
Address
Address of the directory.
Layout
Layout associated with the directory.
Publisher
Publisher of the directory.
Operation
Operations you can do for the directory, such as changing the layout.
Changing a Layout
 - Click
 - Click Change Layout in the Operation column of the target directory.
 - On the Change Layout page, select the layout to be changed.
 - Click OK.
