Managing Incident Types
This section describes how to manage incident types. The detailed operations are as follows:
- Viewing Incident Types: describes how to view existing incident types and their details.
- Adding an Incident Type: describes how to create custom incident types.
- Associating an Incident Type with a Layout: describes how to associate a custom incident type with an existing incident type.
- Editing an Incident Type: describes how to edit a custom incident type.
- Managing Existing Incident Types: describes how to enable, disable, and delete a custom incident type.
Limitations and Constraints
- By default, built-in incident types are associated with existing layouts. You cannot customize associated layouts.
- Built-in incident types are enabled by default and cannot be edited, enabled, disabled, or deleted.
- After a customized incident type is added, the Type Name, Type ID, and Subtype ID parameters cannot be modified.
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose . On the displayed page, click the Type Management tab.
Figure 1 Type Management page
- On the Type Management page, click the Event Types tab.
- On the Event Types tab, view the details about existing incident types. For details about the parameters, see Table 1.
Table 1 Incident type parameters Parameter
Type Name
Name of an incident type
Sub Type/Sub Type Tag
Name and ID of an incident subtype
Associated Layout
Layout associated with the incident type
Startup Status
Indicates whether an incident type is enabled.
- Enable: The current type has been enabled.
- Disabled: The current type has been disabled.
SLA
SLA processing time of an incident type
Description of an incident type
Operation
You can edit and delete incident types.
- Click
Figure 2 Type Management page
- On the Event Types tab, click Add. On the Add Event Type slide-out panel, set incident type parameters.
Table 2 Incident type parameters Parameter
Type Name
Customized name of an incident type.
Type Tag
Enter the incident type ID. The keyword must comply with the upper camel case naming rules, for example, TypeTag.
Sub Type
Enter the subtype of the incident type.
Sub Type Tag
Enter the incident subtype ID. The keyword must comply with the upper camel case naming rules, for example, SubTypeName.
Startup Status
SLA
Set the SLA processing time of the incident.
Description of a custom incident type
- In the lower right corner of the page, click OK.
After the incident type is added, you can view the new incident type in Type Name on the Event Type page.
- Click
Figure 3 Type Management page
- On the Event Type page, select the incident type to be associated with a layout and click Associated Layout in the Operation column of the target type.
- In the Associate Layout dialog box, select the target layout and click OK.
- Currently, the built-in incident type cannot be edited.
- Click
Figure 4 Type Management page
- In Type Name on the Alarm Types page, click the name of the customized incident type to be edited. Details about the custom incident type are displayed on the right.
- On the Event Type page, click Edit in the Operation column of the target type to be edited.
- In the Edit Event Type dialog box, edit parameters.
Table 3 Incident type parameters Parameter
Type Name
Name of an incident type, which cannot be modified.
Type Tag
Incident type ID, which cannot be modified.
Sub Type
Sub Type Tag
Incident subtype ID, which cannot be modified.
Startup Status
SLA
- Click
Figure 5 Type Management page
- On the incident type tab, manage incident types.
- The built-in incident types are enabled by default. You do not need to manually enable them.
- Currently, built-in incident (event) types cannot be disabled or deleted.
Table 4 Managing existing incident types Operation
Enable
- On the type management page, select the type to be enabled and click Batch Enable.
Alternatively, locate the row containing the incident type to be enabled, and click Disable in the Status column.
- In the dialog box displayed, click OK.
If the system displays a message indicating that the operation is successful and the status of the target type changes to Enable, the target type is enabled successfully.
Disable
- On the Event Type page, select the type to be disabled and click Batch Disable.
Alternatively, locate the row containing the incident type to be disabled, and click Enable in the Status column.
If the system displays a message indicating that the operation is successful and the Status of the target type changes to Disable, the target type is disabled successfully.
Delete
- On the incident type management page, select the type to be deleted and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE and click OK.
