Updated on 2025-06-26 GMT+08:00
Adding and Editing an Indicator
The indicator library list displays information about all your indicators.
This section describes how to create and edit an indicator.
  • Adding an Indicator: If a potential threat to the system and users is detected, you can add indicators to record the threat. In this way, the security personnel can quickly take measures to protect personnel, information, and assets, and accelerate threat detection and rectification.
  • Editing an Indicator: If the threat level, status, and owner of an indicator changes, you can edit the indicator information.
Adding an Indicator
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Threats > Indicators.
  5. On the Indicators page, click Add. On the Add page, set parameters.
    Table 1 Indicator parameters
    Indicator Name
    Name of a user-defined threat indicator. The value can contain:
    Only uppercase letters, lowercase letters, digits, and the special characters: -_ ()
    Type
    Indicator type. Options: IPv6, URL, Other, Email, Domain name, and IPv4.
    Threat Degree
    Select a threat degree level.
    • Black: dangerous
    • Gray: minor
    • White: secure
    Data Source Product Name
    Data source product name
    Data Source Type
    Type of the data source. The options are Cloud Service, Third-party, and Private.
    Status
    Indicator status. Possible values are Open, Closed, and Revoked.
    • Open
    • Closed: If the threat corresponding to the indicator is eliminated, you can close the indicator.
    • Revoked: If an indicator is incorrect or the threat scenario described by the indicator does not exist, you can revoke or delete the indicator. Deleted indicators cannot be restored. Exercise caution when performing this operation.
    Confidence
    Reliability of the selected indicator. The value ranges from 80 to 100.
    Owner
    Primary owner of the indicator.
    Labels
    Label of a user-defined counter.
    First Occurrence Time
    First occurrence time of the indicator.
    Last Occurrence Time
    Latest occurrence time of the indicator.
    Expiration Time
    Expiration time of the indicator.
    Invalid or not
    Whether to invalidate the indicator. The default value is No.
    Granularity
    Granularity of the indicator.
    Display Name
    If Type is set to Email, you can customize the display name of an email.
    Familial
    If Type is set to Domain name, you can customize the family the domain name belongs to.
    Email Account
    If Type is set to IPv6, IPv4, Email, or Domain name, you can configure a custom email account.
    Region
    If Type is set to IPv6 or IPv4, you can configure the region an IP address belongs to.
    URL
    If Type is set to URL, you can customize URL information.
    DNS Category
    If Type is set to Domain name, you can customize the DNS category for the domain name.
    Description of the custom indicator.
    Value
    Enter the indicator value, such as IP, URL, and domain.
  6. Click OK.
  5. On the Indicators page, locate the target indicator and click Edit in the Operation column.
  6. On the Edit page that is displayed, edit indicator parameters.
    Table 2 Indicator parameters
    Indicator Name
    Type
    Indicator type.
    Threat Degree
    • Black: dangerous
    • Gray: minor
    • White: secure
    Name of the data source, which cannot be changed
    Data Source Type
    Type of the data source, which cannot be changed
    Status
    Confidence
    Owner
    Labels
    Label of a user-defined indicator.
    Expiration Time
    Invalid or not
    Granularity
    MD5
    Enter the MD5 value of the indicator.
    SHA1
    Enter the SHA1 value of the indicator.
    SHA256
    Enter the SHA-256 value of the indicator.
    File type
    Enter the file type of the indicator.
    Compile Time
    Enter the compilation time of the indicator.
    File Name
    Enter the file name of the indicator.
    File MIME Type
    Enter the MIME type of the indicator file.
    Familial
    Enter the family the indicator belongs to.
    Category
    Enter the type of the indicator.
  7. Click OK.
