Managing Workflows
This topic describes how to manage workflows, including Viewing Workflows, Exporting Workflows, Deleting Workflows, Copying a Workflow, and Disabling a Workflow.
Viewing Workflows
- Click
in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the navigation pane on the left, choose Security Orchestration > Playbooks. On the displayed page, select the Workflows tab.
Figure 1 Workflows tab
- On the Workflows page, view details about the created workflow.
Figure 2 Viewing workflows
- The numbers of Pending review, Not enabled, and Enabled workflows are displayed above the workflow list.
- View information about existing workflows in the workflow list.
If there are many workflows displayed, use filters to search for a specific one.
Table 1 Workflow parameters Parameter
Name
Workflow name
Data Class
Data class corresponding to a workflow.
Workflow Status
Current status of a workflow. The status can be Enabled or Disabled.
Workflow Type
Current type of a workflow.
Current Version
Current version of a workflow.
Created By
User who creates the workflow.
Created
Time when a workflow was created
Updated By
User who modifies the workflow last time.
Updated At
Time when a workflow is last updated.
A description of the workflow.
Operation
You can perform operations such as enabling and managing versions in the Operation column.
- To view details about a workflow, click its name to access its details page.
Exporting Workflows
Only workflows in the Enabled state can be exported.
- Click
Figure 3 Workflows tab
- On the Workflows tab page, select the workflows to be exported and click
in the upper right corner of the list. - In the dialog box that is displayed, click OK. The system exports the workflows to the local host.
Deleting Workflows
- The workflow is in the Disabled state.
- The workflow does not contain an activated workflow version.
- Click
Figure 4 Workflows tab
- On the Workflows tab page, locate the row containing the target workflow and click Delete in the Operation column.
During deletion, all historical versions in the current workflow are deleted by default. Deleted versions cannot be restored.
- Click
Figure 5 Workflows tab
- In the row containing the target workflow, click Disable in the Operation column.
Copying a Workflow
- Click
Figure 6 Workflows tab
- In the Operation column of the target workflow, click Copy Workflow to open the Copy Workflow dialog box.
- In the Copy Workflow dialog box, configure the following parameters.
Table 2 Parameters for copying a workflow Parameter
Source Version
Select the version you want to copy and click OK. A new workflow will be generated.
To copy a workflow, there must be at least one existing workflow version.
You can only select a value from the drop-down list.
Workflow Name
Specify a name for the new workflow.
- The workflow name must be unique.
- The workflow name cannot be empty.
- The workflow name can contain 1 to 64 characters. Only letters, digits, periods (.), hyphens (-), underscores (_), and spaces are allowed.
- Click OK. You can check the new workflow information on the Workflows tab. Now, you need to submit the workflow version for review before enabling it. For details, see Editing and Submitting a Workflow Version, Reviewing a Workflow Version, and Enabling a Workflow.
