Updated on 2025-11-11 GMT+08:00
Managing Playbook Versions
Previewing Playbook Versions
The draft version cannot be previewed.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Security Orchestration > Playbooks.
    Figure 1 Accessing the Playbooks tab
  5. On the Playbooks tab, click Version Management in the Operation column of the playbook.
  6. On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Preview in the Operation column.
  7. On the playbook version preview page, you can view the details about the target playbook version, including Basic Information, Version Information, and Matching Workflow.
Editing a Playbook Version
Only playbook versions whose version status is Unsubmitted can be edited.
    Figure 2 Accessing the Playbooks tab
  6. On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Edit in the Operation column.
  7. On the page for editing a playbook version, edit the version information.
  8. Click OK.
Activating/Deactivating a Playbook Version
  • Only the playbook version that is not activated can be activated.
  • Only one activated version is allowed for each playbook.
  • After the current version is activated, the previously activated version is deactivated. For example, if the V2 version is activated this time, the V1 version in the activated state is deactivated and changes to the deactivated state.
    Figure 3 Accessing the Playbooks tab
  6. On the Version Management page, in the version information area, locate the row containing the desired playbook version, and click Activate or Deactivate in the Operation column.
Copying a Playbook Version
Only playbook versions in the Activated or Inactive state can be copied.
    Figure 4 Accessing the Playbooks tab
  6. On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Copy in the Operation column.
  7. In the dialog box that is displayed, click OK.
Deleting a Playbook Version
To delete a playbook version, the following conditions must be met:
  • The playbook version is inactivated.
  • No running playbook version instance exists.
    Figure 5 Accessing the Playbooks tab
  6. On the Version Management slide-out panel, in the version information area, locate the row containing the desired playbook version, and click Delete in the Operation column.
    After a playbook version is deleted, it cannot be retrieved. Exercise caution when performing this operation.
