Help Center/
      SecMaster/
        User Guide (Kuala Lumpur Region)/
        Threats/
        Indicators/
      Closing and Deleting an Indicator
        Updated on 2025-06-26 GMT+08:00
This topic describes how to close and delete an indicator.
- Disabling indicators: If the threat corresponding to an indicator is eliminated, you can close the indicator.
 - Deleting an indicator: If the indicator is incorrect or the threat scenario described by the indicator does not exist, you can delete the indicator. Deleted indicators cannot be restored. Exercise caution when performing this operation.
 - Click
 in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
 - In the navigation pane on the left, choose .
 - On the Indicators page, close or delete an indicator.
Table 1 Indicator parameters Operation
Close
- On the Indicator page, locate the row that contains the target indicator, click Close in the Operation column. The Close dialog box is displayed.
 - In the dialog box that is displayed, select the close reason and enter comments.
 - Click OK.
Delete
- On the Indicators page, locate the target indicator and click Delete in the Operation column.
 - In the dialog box displayed, click OK.
   Parent topic: Indicators
