Updated on 2025-06-26 GMT+08:00
Adding and Editing an Incident
This section describes how to add or edit an incident.
  • Adding an incident: If you identify an attack or a fault that needs to be handled, you can add an incident for tracking and handling the attack or fault.
  • Editing an incident: If information such as the incident status, severity, and owner changes, you can edit the incident accordingly.
Adding an Incident
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Threats > Incidents.
  5. On the Incidents page, click Add. On the displayed Add page, set parameters as described in Table 1.
    Table 1 Parameters for adding an incident
    Basic Information
    Incident Name
    Custom incident name. The value must contain:
    • Only uppercase letters, lowercase letters, digits, and the special characters: -_ ()
    • A maximum of 2,550 characters
    Type
    Select an incident type from the drop-down list.
    (Optional) Service ID
    Enter the service ID corresponding to the incident.
    Incident Severity
    Select a severity level.
    The options are Critical, High, Medium, Low, and Informational.
    Status
    Select an incident status.
    The options are Open, Blocked, and Closed.
    • Open: Select Open if the incident has not been handled or the fault still exists.
    • Blocked: Select Blocked if the incident cannot be handled or resolved due to a specific reason.
    • Closed: Select Closed if the incident has been handled, the issue has been resolved, or the fault no longer exists.
    (Optional) Owner
    Primary owner of the incident.
    Data Source Product Name
    Select the name of the data source product.
    Data Source Type
    Select a data source type. For example, if the source is a cloud service, select Cloud Service.
    Timeline
    First Occurrence Time
    Configure the time when the incident occurred first time.
    (Optional) Last Occurrence Time
    Configure the time when the incident occurred last time.
    (Optional) Planned Closure Time
    Time to close the incident.
    Other
    (Optional) Verification Status
    Verification status of the incident to identify the accuracy of the incident.
    • Unknown: It is unclear whether the incident may lead to an attack.
    • Attack succeeded: The incident was triggered by a successful attack.
    • Attack failed: The incident was triggered by a failed attack.
    (Optional) Stage
    Select the incident phase.
    • Preparation: Prepare resources to process incidents.
    • Detection and analysis: Detect and analyze the cause of an incident.
    • Containment, extradition, and recovery: Handle an incident.
    • Post Incident Activity: Follow-up activities.
    (Optional) Debugging data
    Whether to enable simulated debugging
    (Optional) Labels
    Label of the incident. For example, "mining pool", "External connection." Use commas (,) to separate multiple labels.
    Incident description. The value can contain:
    • A maximum of 10,240 characters.
  6. Click OK. You can check the added incident by referring to Viewing Incidents. Path: In the navigation pane on the left, choose Threats > Incidents.
Editing an Incident
  5. In the incident list, locate the row that contains the target incident and click Edit in the Operation column.
  6. On the Edit page that is displayed, edit incident parameters.
    Table 2 Parameters for editing an incident
    Basic Information
    Incident Name
    Incident Type
    Incident type
    Incident Level
    Select a severity level. The options are Critical, High, Medium, Low, and Informational.
    Status
    (Optional) Owner
    Data Source Name
    Name of the data source, which cannot be changed
    Data Source Type
    Type of the data source, which cannot be changed
    Timeline
    Time when the incident occurred first time.
    Time when the incident occurred last time.
    Other
    (Optional) Phase
    Incident phase.
    • Contain, extradition, and recovery: Handle an incident.
    Whether to enable simulated debugging. This parameter cannot be modified once configured.
    (Optional) Label
  7. Click OK. The incident editing is complete. You can check the incident details by referring to Viewing Incidents. Path: In the navigation pane on the left, choose Threats > Incidents.
