Updated on 2025-07-03 GMT+08:00
Closing and Deleting an Alert
This topic describes how to close and delete an alert.
  • Closing an alert: If an alert has been handled and the issue introduced has been resolved, you can close the alert. On the Alerts page, if Status of the alert in the alert list changes to Closed, the alert is closed successfully.
  • Deleting an alert: You can delete an alert in the following scenarios. Only alerts you add or import can be deleted. Deleted alerts cannot be restored.
    • The alert is invalid or irrelevant.
    • The alert is duplicate.
    • No further action is required for expired or historical alerts that are no longer needed.
Limitations and Constraints
  • Only alerts defined or imported by you can be deleted.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
  4. In the navigation pane on the left, choose Threats > Alerts.
  5. On the Alerts page, close or delete an alert.
    Table 1 Managing alerts
    Operation
    Closing an alert
    1. Locate the row that contains the target alert, click Close in the Operation column. A dialog box is displayed for you to confirm the close operation.
      To close multiple alerts, select the alerts in the alert list and click Batch Close above the list.
    2. In the confirmation dialog box, select Reason for, enter Close Comment, and click OK.
    3. In the alert list on the Alerts page, if Status of the alert changes to Closed, the alert is closed successfully.
    Deleting an alert
    1. Locate the row that contains the target alert, click More in the Operation column, and select Delete. The deletion confirmation dialog box is displayed.
      To delete multiple alerts, select the alerts in the alert list and click More > Batch Delete above the list.
    2. In the displayed dialog box, click OK.
    3. If an alert is deleted, the alert information will be no longer displayed in the alert list on the Alerts page.
      Deleted alerts cannot be restored. Exercise caution when deleting an alert.
