Overview
SecMaster can deliver data to other pipelines or other cloud products in real time so that you can store data or consume data with other systems. After data delivery is configured, SecMaster periodically delivers the collected data to the specified pipelines or cloud products.
Category |
Delivery Scenario |
Scenario Description |
Data delivery scenarios |
You can deliver logs to other data pipelines. |
You can deliver logs to an Object Storage Service (OBS) bucket. |
You can deliver logs to Log Tank Service (LTS). |
Managing data delivery tasks |
You can view, suspend, start, and delete a data delivery task. |
Advantages
- Simple operation: You only need to complete simple configurations on the console to deliver SecMaster data to other cloud products such as OBS.
- Data centralization: SecMaster has completed data centralization of different services. You only need to deliver the collected data to other cloud products such as OBS for centralized data management.
- Category management: When collecting data, the SecMaster manages the data by category. You can use this function to deliver data of different projects and types to different cloud products.
- This function is supported only by SecMaster standard and professional editions. The basic edition does not support this function.
- Access to cloud service logs have been enabled in SecMaster, and there is data in SecMaster pipelines. For details about how to access cloud service logs, see Enabling Log Access.
- If you want to deliver data to an OBS bucket, the bucket must have private, public read, or public read/write policy enabled. Currently, parallel file buckets are not supported.
- To deliver data to LTS, ensure there are available log groups and log streams.
Limitations and Constraints
- When performing cross-account delivery, the data can only be delivered to the pipelines instead of cloud services of other accounts.
- If the new data delivery is cross-account, you need to log in to SecMaster using the destination account and authorize the delivery.
