Updated on 2025-11-11 GMT+08:00
Log Fields
This section describes the meaning of each field.
Common Fields
Table 1 Common fields
Field Type
__time
Date
Time when a log is generated
__raw
String
Raw log
ops.source
String
Data source
ops.rgn
String
Site
ops.csvc
String
Data source (cloud service)
ops.ver
String
Data warehouse version
ops.hash
String
Integrity verification of extend hash value of original
[src_/dest_]asset.domain.id
String
Domain ID
[src_/dest_]asset.domain.name
String
Domain name
[src_/dest_]asset.id
String
Asset ID
[src_/dest_]asset.name
String
Asset name
[src_/dest_]asset.type
String
Asset type
[src./dest.]asset.region
String
Asset site
[src_/dest_]geo.ip
String
IP address
[src_/dest_]geo.country
String
Country name (Chinese)
[src_/dest_]geo.prov
String
Province name (Chinese)
[src_/dest_]geo.city
String
City name (Chinese)
[src_/dest_]geo.org
String
Organization that registers the IP address
[src_/dest_]geo.isp
String
Carrier
[src_/dest_]geo.loc.lat
Float
Latitude
[src_/dest_]geo.loc.lon
Float
Longitude
[src_/dest_]geo.tz
Integer
Time zone
[src_/dest_]geo.utc_off
Integer
Time zone
[src_/dest_]geo.cac
String
Time zone
[src_/dest_]geo.iddc
String
International call prefix code
[src_/dest_]geo.cc
String
Country code (ISO)
[src_/dest_]geo.contc
String
Continental code (ISO)
[src_/dest_]geo.idc
String
Data center (equipment room)
[src_/dest_]geo.bs
String
Mobile base station
[src_/dest_]geo.cc3
String
Country code (3 digits)
[src_/dest_]geo.euro
String
EU member states
sec-waf-attack
Fields in WAF attack logs
Table 2 sec-waf-attack
Field
Type
category
String
Category. The value is attack.
time
Date
Log time.
time_iso8601
Date
ISO 8601 time of the log.
policy_id
String
Protection policy ID.
level
Integer
Protection policy level. The value can be 1 (loose), 2 (medium), or 3 (strict).
attack
String
Attack type. The value can be:
  • default: default attacks
  • xss: cross-site scripting (XSS) attacks
  • sqli: SQL injections
  • cmdi: command injections
  • lfi: local file inclusion attacks
  • rfi: remote file inclusion attacks
  • webshell: web shells
  • robot: crawler attacks (blocked based on the user agent blacklist)
  • vuln: vulnerability exploits
  • cc: attacks that hit the CC rules
  • custom_custom: attacks that hit a precise protection rule
  • custom_whiteip: attacks that hit a whitelist rule
  • custom_geoip: attacks that hit a geolocation rule
  • illegal: unauthorized requests
  • anticrawler: attacks that hit the anti-crawler rule, such as JS challenges
  • antitamper: attacks that hit a web tamper protection rule
  • leakage: attacks that hit a sensitive data protection rule
  • followed_action: attacks that hit a known attack source rule
  • trojan: website Trojan
action
String
Processing action. The value can be:
  • block: WAF blocks attacks.
  • log: WAF only logs detected attacks.
  • captcha: A verification code is required.
rule
String
ID of the triggered rule or the description of the custom policy type.
sub_type
String
When attack is set to robot, this field cannot be left blank. It indicates the subtype of a crawler.
  • script_tool: script tools
  • search_engine: search engines
  • scanner: scanning tools
  • uncategorized: other crawlers
location
String
Location of the triggered payload.
resp_headers
String
Response header.
resp_body
String
Response body.
hit_data
String
Triggered payload string.
status
String
Status code of the response to the request.
reqid
String
Random ID.
id
String
Attack ID.
method
String
Request method.
sip
String
Request IP address of the client.
sport
String
Request port of the client.
host
String
Domain name of the requested server.
http_host
String
Port number of the requested server.
uri
String
Request URL.
header
String
Request header information.
multipart
String
Request multipart header (file upload).
cookie
String
Request cookie.
params
String
Parameters following the request URI.
body_bytes_sent
String
Total number of bytes of the response body sent to the client.
upstream_response_time
String
Response time of the backend server.
process_time
String
Detection duration of the engine.
engine_id
String
Unique ID of the engine.
group_id
String
Log group ID used for interconnecting with LTS.
attack_stream_id
String
ID of access_stream of the user in the log group identified by the group_id field.
hostid
String
ID of a protected domain name.
tenantid
String
Tenant ID of the protected domain name.
projectid
String
Project ID of the protected domain name.
backend
Object
Address of the backend server to which the request is forwarded.
backend
type
String
Backend host type (IP address or domain name).
alive
String
Backend host status.
host
String
Backend host value.
protocol
String
Backend protocol.
port
Integer
Backend port.
sec-waf-access
Table 3 describes the fields in WAF access logs.
Table 3 sec-waf-access
Field
Type
requestid
String
Random ID
time
Date
Log time
eng_ip
String
Engine IP address
hostid
String
tenantid
String
projectid
String
remote_ip
String
IP address of the client that sends the request
scheme
String
Request protocol type
response_code
String
Response code of a request
method
String
Request method
http_host
String
url
String
Request URL
request_length
String
Request length
bytes_send
String
Total number of bytes sent to the client
body_bytes_sent
String
upstream_addr
String
IP address of the selected backend server
request_time
String
Request processing time, which starts from the first byte sent from the client
String
upstream_status
String
Response code of the backend server
upstream_connect_time
String
Duration for connecting to the backend server
upstream_header_time
String
Time used by the backend server to receive the first byte of the response header
bind_ip
String
Retrieval IP address of the engine
engine_id
String
time_iso8601
Date
sni
String
Domain name requested through the SNI
tls_version
String
Version of the protocol used to establish an SSL connection
ssl_curves
String
List of curves supported by the client
ssl_session_reused
String
Whether an SSL session is reused.
  • r: It is reused.
  • .: It is not reused.
process_time
String
x_forwarded_for
String
Content of X-Forwarded-For in the request header
cdn_src_ip
String
Content of Cdn-Src-Ip in the request header
x_real_ip
String
Content of X-Real-Ip in the request header
sec-obs-access
Fields in OBS access logs
Table 4 sec-obs-access
Field
Type
srcip
String
Source IP address for accessing OBS.
srcport
String
Source port for accessing OBS.
logtime
Date
Time when the log is generated.
ces_log_version
String
Version number, which is V0 for an internal request. V0 does not record Cloud Eye audit logs, and V1 records Cloud Eye audit logs.
request_start_time
String
Request start time.
ctx_request_id
String
Request ID, which uniquely identifies a request to be traced.
request_method
String
Request method (GET/POST).
remote_ip
String
Remote IP address, in the format of Client IP address:Port number.
operation
String
Operation type, for example, GET.OBJECT.
bucket_name
String
Bucket name.
object_name
String
Object name (file name).
query_string
String
Request query.
http_status
String
HTTP request status code, for example, 200.
content_length
String
Length of the requested content.
user_agent
String
Client agent.
storage_class
String
OBS storage class.
user_name
String
Username of the requester.
user_id
String
User ID of the requester.
domain_name
String
Domain name of the requester.
domain_id
String
Domain ID of the requester.
project_id
String
Project ID of the requester.
owner_domain_name
String
Tenant name of the bucket owner.
owner_domain_id
String
Tenant ID of the bucket owner.
owner_project_id
String
Project ID of the bucket owner.
transmission_type
String
Network type. The value can be:
  • 1: intranet
  • 2: public network
scheme
String
Network protocol.
http_version
String
HTTP version.
host
String
OBS domain name.
port
String
Port number.
auth_v2_v4
String
Authentication mode.
host_type
String
Access type.
x_forwarded_for
String
IP address of the proxy client.
pub_bkt
String
Whether the bucket is accessed anonymously.
pub_obj
String
Whether an object is accessed anonymously.
website_req
String
Whether the request is a website request.
crr_req
String
Whether the request is a CRR request.
batch_delete_success_count
String
Number of successful batch deletions.
ctc_log_urn
String
Agency.
requester
String
Agency account.
is_over_write
String
Whether to overwrite data.
error_code
String
Cause of an error.
detail_error_code
String
Detailed error cause.
request_content_type
String
Request object type.
request_content_md5
String
MD5 of the request object.
total_bytes_received
String
Total bytes of received content.
response_content_type
String
Response object type.
total_bytes_sent
String
Total bytes of sent content in the response header and response body.
referrer
String
Reference page.
index_read_count
String
Metadata table query latency.
persistence_read_count
String
Number of times that data is read.
vpc_id
String
ID of the VPC to which the request client belongs.
access_with_security_token
String
Access using the STS token.
copy_size
String
Copy size.
vpcep_traffic
String
Transmission through VPCEP.
access_key
String
AK.
sec-nip-attack
Fields in IPS attack logs
Table 5 sec-nip-attack
Field
Type
SyslogId
String
Log serial number (SN).
Vsys
String
Virtual system name.
Policy
String
Name of a security policy.
SrcIp
String
Source IP address of a packet.
DstIp
String
Destination IP address of a packet.
SrcPort
String
Source port of a packet. For an ICMP packet, the value of this field is 0.
DstPort
String
Destination port of a packet. For an ICMP packet, the value of this field is 0.
SrcZone
String
Source security zone of a packet.
DstZone
String
Destination security zone of a packet.
User
String
Username.
Protocol
String
Protocol of the packet detected by a signature.
Application
String
Application that the packet detected by a signature belongs to.
Profile
String
Name of a configuration file.
SignName
String
Name of a signature.
SignId
String
ID of a signature.
EventNum
String
This field is introduced for log merging. Whether to merge logs depends on the merging frequency and log merging conditions. If logs are not merged, the value is 1.
Target
String
Object attacked by the packet detected by a signature. The value can be:
  • server: The attack object is the server.
  • client: The attack object is the client.
  • both: The attack objects are both the server and the client.
Severity
String
Severity of the attack caused by the packet detected by a signature. The value can be:
  • information
  • low
  • medium
  • high
Os
String
OS attacked by the packet detected by a signature. The value can be:
  • all: all OSs
  • android: Android
  • ios: iOS
  • unix-like: Unix
  • windows: Windows
  • other: other OSs
Category
String
Threat type of the detected attack packet features.
Action
String
Signature action.
  • Alert
  • Block
Reference
String
Reference information about the signature.
Extend
String
Evidence collection field in enhanced mode.
sec-hss-vul
Fields in HSS vulnerability scanning results
Table 6 sec-hss-vul
Field
Type
agentUuid
String
Agent UUID.
alarmCsn
String
Alert UUID, which is randomly generated when the master generates an alert.
alarmKey
String
Alert keyword. For an alert, it is the msg_id reported by the transparent transmission agent. For a vulnerability, it is generated by the master.
alarmVersion
String
Agent version.
occurTime
Int64
Vulnerability detection time (ms).
severity
Int32
Vulnerability level defined by HSS.
hostUuid
String
UUID of the affected host.
hostName
String
Name of the affected host.
hostIp
String
Communication IP address of the affected host.
ipList
String
List of IP addresses of affected hosts.
cloudId
String
CloudAgent SN.
region
String
Region where the affected host is located.
projectId
String
Project ID.
enterpriseProjectId
String
Enterprise project ID.
appendInfo
Object
Vulnerability details.
appendInfo
vulId
String
Official vulnerability ID.
type
Int32
Vulnerability type. The value can be:
  • 0: Linux
  • 1: Windows
  • 2: Web CMS
repairNecessity
Int32
Necessity level of vulnerability fixing. The value can be:
  • 1: low-risk
  • 2&3: medium-risk
  • 4: high risk
status
Int32
Reserved field.
cve_ids
String
CVE ID list. Use commas (,) to separate CVE IDs.
url
String
URL of the official website where the vulnerability details are available.
vulNameEn
String
Vulnerability name in English.
vulNameCn
String
Vulnerability name in Chinese.
severityLevel
String
Vulnerability severity. The options are as follows:
  • Critical
  • High
  • Medium
  • Low
descriptionEn
String
Vulnerability description in English.
descriptionCn
String
Vulnerability description in Chinese.
solutionEn
String
Solution description in English.
solutionCn
String
Solution description in Chinese.
repairCmd
String
Fix command.
needBoot
Int32
Whether to restart the system. The default value is 1, which means not to restart the system.
errorInfo
String
Fix failure cause.
appName
String
Name of the software that has the vulnerability (only for Linux vulnerabilities).
version
String
Version of the software that has the vulnerability (only for Linux vulnerabilities).
createTime
Int64
First detection time (ms).
updateTime
Int64
Vulnerability fixing time (ms). The initial value is the same as that of createTime.
agentId
String
UUID of the associated host agent.
projectId
String
ID of the affected tenant.
sec-hss-alarm
Fields in HSS alert logs
Table 7 sec-hss-alarm
Field
Type
agentUuid
String
Agent UUID.
alarmCsn
String
Alert UUID.
alarmKey
String
alarmVersion
String
Agent version.
occurTime
Long
Incident occurrence time (accurate to millisecond).
severity
Long
Severity.
hostUuid
String
hostName
String
hostIp
String
ipList
String
cloudId
String
CloudAgent SN.
region
String
projectId
String
Project ID.
enterpriseProjectId
String
appendInfo
Object
Alert details.
appendInfo
agent_id
String
Agent ID.
version
String
Incident version.
container_name
String
Container ID (in container security scenarios).
image_name
String
Image name (in container security scenarios).
event_id
String
Incident ID (GUID).
event_name
String
Incident name.
event_classid
String
Unique incident ID.
occur_time
Long
Occurrence time (accurate to second).
recent_time
Long
Last occurrence time (accurate to second).
event_category
Integer
Incident category.
event_type
Integer
Incident type.
event_count
Integer
Number of incidents.
severity
Integer
Severity.
attack_phase
Integer
Attack phase.
attack_tag
Integer
Attack tag.
confidence
Integer
Confidence.
action
Integer
Action.
detect_module
String
Detection module.
report_source
String
Report source.
related_events
String
Related incident ID.
resource_info
Object
Resource information.
network_info
Object
Network information.
app_info
Object
Application information.
system_info
Object
System information.
process_info
list
Process information.
user_info
list
User information.
file_info
list
File information.
geo_info
Object
Geographic information.
malware_info
Object
Malware information.
forensic_info
String
Evidence collection field.
recommendation
String
Handling suggestions.
extend_info
String
Extended incident information.
resource_info
project_id
String
Project ID.
region_name
String
Region name.
vpc_id
String
VPC ID.
host_name
String
Host name.
host_ip
String
Host IP address.
host_id
String
Host ID (ECS ID).
cloud_id
String
Cloud agent SN.
vm_name
String
VM name.
vm_uuid
String
VM UUID.
container_id
String
Container ID.
image_id
String
Image ID.
sys_arch
String
System CPU architecture.
os_bit
String
OS bit version.
os_type
String
OS type.
os_name
String
OS name.
os_version
String
OS version.
network_info
local_address
String
Local address.
local_port
Integer
Local port.
remote_address
String
Remote address.
remote_port
Integer
Remote port.
src_ip
String
Source IP address.
src_port
Integer
Source port.
src_domain
String
Source domain.
dest_ip
String
Destination IP address.
dest_port
Integer
Destination port.
dest_domain
String
Destination domain.
protocol
String
Protocol.
app_protocol
String
Application layer protocol.
flow_direction
String
Flow direction.
app_info
sql
String
Executed SQL statement.
domain_name
String
DNS domain name.
url_path
String
URL.
url_method
String
URL method.
req_refer
String
URL request referrer.
email_subject
String
Email subject.
email_sender
String
Email sender.
email_receiver
String
Email recipient.
email_keyword
String
Email keyword.
process_info
process_name
String
Process name.
process_path
String
Process file path.
process_pid
Integer
Process ID.
process_uid
Integer
Process user ID.
process_username
String
Process username.
process_cmdline
String
Process file command line.
process_filename
String
Process file name.
process_start_time
Long
Process start time.
process_gid
Integer
Process group ID.
process_egid
Integer
Effective process group ID.
process_euid
Integer
Effective process user ID.
parent_process_name
String
Parent process name.
parent_process_path
String
Parent process file path.
parent_process_pid
Integer
Parent process ID.
parent_process_uid
Integer
Parent process user ID.
parent_process_cmdline
String
Parent process file command line.
parent_process_filename
String
Parent process file name.
parent_process_start_time
Long
Parent process start time.
parent_process_gid
Integer
Parent process group ID.
parent_process_egid
Integer
Effective parent process group ID.
parent_process_euid
Integer
Effective parent process user ID.
child_process_name
String
Subprocess name.
child_process_path
String
Subprocess file path.
child_process_pid
Integer
Subprocess ID.
child_process_uid
Integer
Subprocess user ID.
child_process_cmdline
String
Subprocess file command line.
child_process_filename
String
Subprocess file name.
child_process_start_time
Long
Subprocess start time.
child_process_gid
Integer
Subprocess group ID.
child_process_egid
Integer
Effective subprocess group ID.
child_process_euid
Integer
Effective subprocess user ID.
virt_cmd
String
Virtualization command.
virt_process_name
String
Virtualization process name.
escape mode
String
Escape mode.
escape cmd
String
Command executed after the escape.
user_info
user_id
Integer
User ID.
user_gid
Integer
User GID.
user_name
String
Username.
user_group_name
String
User group name.
user_home_dir
String
User home directory.
login_ip
String
User login IP address.
service_type
String
Login service type.
service_port
Integer
Login service port.
login_mode
String
Login mode.
login_lasttime
Long
Last login time of a user.
login_fail_count
Integer
Failed login attempts.
pwd_hash
String
Password hash.
pwd_with_fuzzing
String
Anonymized password.
pwd_used_days
Integer
Password age (days).
pwd_min_days
Integer
Minimum password validity period.
pwd_max_days
Integer
Maximum password validity period.
pwd_warn_left_days
Integer
Advance warning of password expiration (days).
file_info
file_path
String
File path/name.
file_alias
String
File alias.
file_size
Integer
File size.
file_mtime
Long
Time when the file is last modified.
file_atime
Long
Time when the file is last accessed.
file_ctime
Long
Time when the file status last changes.
file_hash
String
File hash value.
file_md5
String
File MD5 value.
file_sha256
String
File SHA256 value.
file_type
String
File type.
file_content
String
File content.
file_attr
String
File attribute.
file_operation
String
File operation type.
file_change_attr
String
Old/New attribute.
file_new_path
String
New file path.
file_desc
String
File description.
file_key_word
String
File keyword.
is_dir
Boolean
Whether the file is a directory.
fd_info
String
File handle information.
fd_count
Integer
Number of file handles.
forensic_info
monitor_process
String
Monitoring process.
escape_mode
String
Escape mode.
abnormal_port
String
Abnormal port.
geo_info
src_country
String
Source country/region.
src_city
String
Source city.
src_latitude
Long
Source latitude.
src_longitude
Long
Source longitude.
dest_country
String
Destination country/region.
dest_city
String
Destination city.
dest_latitude
Long
Destination latitude.
dest_longitude
Long
Destination longitude.
malware_info
malware_family
String
Malware family.
malware_class
String
Malware classification.
system_info
pwd_valid
Boolean
Whether the password is valid.
pwd_min_len
Integer
Password length.
pwd_digit_credit
Integer
Digits contained in the password.
pwd_uppercase_letter
Integer
Uppercase letters contained in the password.
pwd_lowercase_letter
Integer
Lowercase letters contained in the password.
pwd_special_characters
Integer
Special characters contained in the password.
extend_info
hit_rule
String
Hit rule.
rule_name
String
Rule name.
rulesetname
String
Rule set name.
report_type
String
Reported data type.
ti_info
ti_source
String
Intelligence source.
ti_class
String
Intelligence classification.
ti_threat_type
String
Intelligence threat type.
ti_first_time
Long
First detection time.
ti_last_time
Long
Last detection time.
sec-hss-log
Fields in HSS security logs
Table 8 sec-hss-log
Field
Type
agentUuid
String
Agent UUID.
alarmCsn
String
Alert UUID.
alarmKey
String
alarmVersion
String
Agent version.
occurTime
Long
severity
Long
Severity.
hostUuid
String
hostName
String
hostIp
String
ipList
String
cloudId
String
CloudAgent SN.
region
String
projectId
String
Project ID.
enterpriseProjectId
String
appendInfo
Object
Alert details.
appendInfo
agent_id
String
Agent ID.
version
String
Incident version.
container_name
String
image_name
String
event_id
String
Incident ID (GUID).
event_name
String
Incident name.
event_classid
String
Unique incident ID.
occur_time
Long
recent_time
Long
event_category
Integer
Incident category.
event_type
Integer
Incident type.
event_count
Integer
severity
Integer
Severity.
attack_phase
Integer
Attack phase.
attack_tag
Integer
Attack tag.
confidence
Integer
Confidence.
action
Integer
Action.
detect_module
String
Detection module.
report_source
String
Report source.
related_events
String
resource_info
Object
network_info
Object
app_info
Object
system_info
Object
System information.
process_info
list
user_info
list
User information.
file_info
list
File information.
geo_info
Object
malware_info
Object
forensic_info
String
recommendation
String
extend_info
String
resource_info
project_id
String
Project ID.
region_name
String
Region name.
vpc_id
String
VPC ID.
host_name
String
Host name.
host_ip
String
Host IP address.
host_id
String
Host ID (ECS ID).
cloud_id
String
Cloud agent SN.
vm_name
String
VM name.
vm_uuid
String
VM UUID.
container_id
String
Container ID.
image_id
String
Image ID.
sys_arch
String
os_bit
String
OS bit version.
os_type
String
OS type.
os_name
String
OS name.
os_version
String
OS version.
network_info
local_address
String
Local address.
local_port
Integer
Local port.
remote_address
String
Remote address.
remote_port
Integer
Remote port.
src_ip
String
Source IP address.
src_port
Integer
Source port.
src_domain
String
Source domain.
dest_ip
String
dest_port
Integer
Destination port.
dest_domain
String
Destination domain.
protocol
String
Protocol.
app_protocol
String
flow_direction
String
Flow direction.
app_info
sql
String
domain_name
String
DNS domain name.
url_path
String
URL.
url_method
String
URL method.
req_refer
String
email_subject
String
Email subject.
email_sender
String
Email sender.
email_receiver
String
Email recipient.
email_keyword
String
Email keyword.
process_info
process_name
String
Process name.
process_path
String
Process file path.
process_pid
Integer
Process ID.
process_uid
Integer
Process user ID.
process_username
String
Process username.
process_cmdline
String
process_filename
String
Process file name.
process_start_time
Long
Process start time.
process_gid
Integer
Process group ID.
process_egid
Integer
process_euid
Integer
parent_process_name
String
parent_process_path
String
parent_process_pid
Integer
Parent process ID.
parent_process_uid
Integer
String
String
Long
parent_process_gid
Integer
parent_process_egid
Integer
parent_process_euid
Integer
child_process_name
String
Subprocess name.
child_process_path
String
child_process_pid
Integer
Subprocess ID.
child_process_uid
Integer
Subprocess user ID.
String
String
Long
child_process_gid
Integer
child_process_egid
Integer
child_process_euid
Integer
virt_cmd
String
virt_process_name
String
escape mode
String
Escape mode.
escape cmd
String
user_info
user_id
Integer
User ID.
user_gid
Integer
User GID.
user_name
String
Username.
user_group_name
String
User group name.
user_home_dir
String
login_ip
String
service_type
String
Login service type.
service_port
Integer
Login service port.
login_mode
String
Login mode.
login_lasttime
Long
login_fail_count
Integer
pwd_hash
String
Password hash.
pwd_with_fuzzing
String
pwd_used_days
Integer
pwd_min_days
Integer
pwd_max_days
Integer
pwd_warn_left_days
Integer
file_info
file_path
String
File path/name.
file_alias
String
File alias.
file_size
Integer
File size.
file_mtime
Long
file_atime
Long
file_ctime
Long
file_hash
String
File hash value.
file_md5
String
File MD5 value.
file_sha256
String
File SHA256 value.
file_type
String
File type.
file_content
String
File content.
file_attr
String
File attribute.
file_operation
String
file_change_attr
String
Old/New attribute.
file_new_path
String
New file path.
file_desc
String
File description.
file_key_word
String
File keyword.
is_dir
Boolean
fd_info
String
fd_count
Integer
forensic_info
monitor_process
String
Monitoring process.
escape_mode
String
Escape mode.
abnormal_port
String
Abnormal port.
geo_info
src_country
String
src_city
String
Source city.
src_latitude
Long
Source latitude.
src_longitude
Long
Source longitude.
dest_country
String
dest_city
String
Destination city.
dest_latitude
Long
dest_longitude
Long
malware_info
malware_family
String
Malware family.
malware_class
String
system_info
pwd_valid
Boolean
pwd_min_len
Integer
Password length.
pwd_digit_credit
Integer
Integer
Integer
Integer
extend_info
hit_rule
String
Hit rule.
rule_name
String
Rule name.
rulesetname
String
Rule set name.
report_type
String
Reported data type.
ti_info
ti_source
String
ti_class
String
ti_threat_type
String
ti_first_time
Long
ti_last_time
Long
sec-ddos-attack
Fields in Anti-DDoS attack logs
Table 9 sec-ddos-attack
Field
Type
log_type
String
Log type
time
Date
local time
device_ip
String
Device IP address
device_type
String
Device type (CLEAN: cleaning device; DETECT: detecting device)
direction
String
Log direction (inbound, outbound)
zone_id
String
Protected object ID
zone_name
String
Protected object name
zone_ip
String
IP address
biz_id
String
Business ID
is_deszone
String
Whether the traffic is network segment traffic (true, false)
is_ipLocation
String
Whether the traffic is geographical location traffic (true, false)
ipLocation_id
String
Geographical location ID
total_pps
String
Total pps
total_kbps
String
Total rate in kbps
tcp_pps
String
Rate of TCP packets to the target (in pps)
tcp_kbps
String
Rate of TCP traffic to the target (in kbps)
tcpfrag_pps
String
Rate of TCP fragments to the target (in pps)
tcpfrag_kbps
String
Rate of TCP fragment traffic to the target (in kbps)
udp_pps
String
Rate of UDP packets to the target (in pps)
udp_kbps
String
Rate of UDP traffic to the target (in kbps)
udpfrag_pps
String
Rate of UDP fragments to the target (in pps)
udpfrag_kbps
String
Rate of UDP fragment traffic to the target (in kbps)
icmp_pps
String
Rate of ICMP packets to the target (in pps)
icmp_kbps
String
Total ICMP traffic to the target (in kbps)
other_pps
String
Rate of OTHER packets to the target (in pps)
other_kbps
String
Total OTHER traffic to the target (in kbps)
syn_pps
String
Number of SYN packets to the target (in pps)
synack_pps
String
Number of SYN/ACK packets to the target (in pps)
ack_pps
String
Rate of ACK packets to the target (in pps)
finrst_pps
String
Rate of FIN/Rst packets to the target (in pps)
http_pps
String
Rate of HTTP packets to the target (in pps)
http_kbps
String
Rate of HTTP traffic to the target (in kbps)
http_get_pps
String
Total packet rate of HTTP requests to the target (in pps)
https_pps
String
Rate of HTTPS packets to the target (in pps)
https_kbps
String
Rate of HTTPS traffic to the target (in kbps)
dns_request_pps
String
Rate of DNS Query packets to the target (in pps)
dns_request_kbps
String
Rate of DNS Query traffic to the target (in kbps)
dns_reply_pps
String
Rate of DNS Reply packets to the target (in pps)
dns_reply_kbps
String
Rate of DNS Reply traffic to the target (in kbps)
sip_invite_pps
String
Rate of SIP packets to the target (in PPS).
sip_invite_kbps
String
Rate of SIP traffic to the target (in kbps)
tcp_increase_con
String
Number of new TCP connections to the target per second
udp_increase_con
String
Number of new UDP connections to the target per second
icmp_increase_con
String
Number of new ICMP connections to the target per second
other_increase_con
String
Number of OTHER connections to the target per second
tcp_concur_con
String
Number of concurrent TCP connections to the target
udp_concur_con
String
Number of concurrent UDP connections to the target
icmp_concur_con
String
Number of concurrent ICMP connections to the target
other_concur_con
String
Number of concurrent OTHER connections to the target
total_average_pps
String
Average pps of all traffic to the target
total_average_kbps
String
Average Kbps of all traffic to the target
sec-cts-audit
Fields in CTS logs
Table 10 sec-cts-audit
Field
Type
time
Date
Time when an incident occurs. The value is the local standard time (GMT+local time zone), for example, 2022/11/08 11:24:04 GMT+08:00.
user
Object
Cloud account used to perform the recorded operation.
request
Object
Requested operation.
response
Object
Response to the request.
service_type
String
Operation source.
resource_type
String
Resource type.
resource_name
String
Resource name.
resource_id
String
Unique resource ID.
source_ip
String
IP address of the user who performs an operation. The value of this parameter is empty if the operation is triggered by the system.
trace_name
String
Operation name.
trace_rating
String
Level of an operation incident. The options are as follows:
  • normal: The operation succeeded.
  • warning: The operation failed.
  • incident: The operation caused a serious consequence, for example, a node failure or service interruption.
trace_type
String
Operation type. The options are as follows:
  • ConsoleAction: operations performed on the management console
  • SystemAction: operations triggered by system
  • ApiCall: operations triggered by invoking API Gateway
  • ObsSDK: operations on OBS buckets, which were triggered by calling OBS SDKs
  • Others: operations on OBS buckets except those triggered by calling OBS SDKs
api_version
String
API version of the cloud service on which an operation was performed.
message
Object
Supplementary information.
record_time
Long
Time when the operation was recorded, in the form of a timestamp.
trace_id
String
Unique operation ID.
code
Integer
HTTP return code, for example, 200 or 400.
request_id
String
Request ID.
location_info
String
Additional information required for fault locating after a request error.
endpoint
String
Endpoint of the page that displays details of cloud resources involved in this operation.
resource_url
String
Access link (excluding the endpoint) of the page that displays details of cloud resources involved in this operation.
user_agent
String
Type of OBS bucket-related operations that are not invoked using OBS SDKs.
content_length
Long
Length of the request body for performing operations on OBS buckets.
total_time
Long
Response time of the request in OBS bucket-related operations.
sec-cfw-risk
Fields in CFW attack event logs
Table 11 sec-cfw-risk
Field
Type
event_time
Date
Attack time
action
String
Response action of CFW
  • permit
  • deny
app
String
Application type
attack_rule
String
Defense rule that works for the detected attack
attack_rule_id
String
ID of the defense rule that works for the detected attack
attack_type
String
Type of the attack
  • Vulnerability exploit
  • Vulnerability scan
  • Trojan
  • Worms
  • Phishing
  • Web attacks
  • Application DDoS
  • Buffer overflow
  • Password attacks
  • Mail
  • Access control
  • Hacking tools
  • Hijacking
  • Protocol exception
  • Spam
  • Spyware
  • DDoS flood
  • Suspicious DNS activities
  • Other suspicious behaviors
dst_ip
String
dst_port
String
Destination port number
packet
String
Original data packet of the attack log
protocol
String
Protocol type
level
String
Level of detected threats
  • CRITICAL
  • HIGH
  • MIDDLE
  • LOW
source
String
Defense for the detected attack
  • 0: basic defense
  • 1: virtual patch
src_ip
String
Source IP address
src_port
String
Source port number
direction
String
Flow direction
  • out2in: inbound
  • in2out: outbound
sec-cfw-flow
Fields in CFW traffic logs
Table 12 sec-cfw-flow
Field
Type
app
String
Application type
dst_ip
String
dst_port
String
end_time
Date
Flow end time
protocol
String
Protocol type
to_c_bytes
String
Number of bytes sent from the server to the client
to_c_pkts
String
Number of packets sent from the server to the client
to_s_bytes
String
Number of bytes sent from the client to the server
to_s_pkts
String
src_ip
String
Source IP address
src_port
String
Source port number
start_time
Date
Flow start time
sec-cfw-block
Fields in CFW access control logs
Table 13 sec-cfw-block
Field
Type
hit_time
Date
Time of access
action
String
  • permit
  • deny
app
String
Application type
dst_ip
String
dst_port
String
protocol
String
Protocol type
rule_id
String
ID of the triggering rule
src_ip
String
Source IP address
src_port
String
Source port number
sec-apig-access
Fields in API Gateway access logs
Table 14 sec-apig-access
Field
Type
region_id
String
Site.
api_id
String
API ID.
body_bytes_sent
String
Response body size.
bytes_sent
String
Size of the entire response.
domain
String
Public network domain name.
errorType
String
Status of request throttling. Value 1 indicates that request throttling is enabled.
http_user_agent
String
User agent ID.
http_x_forwarded_for
String
X-Forwarded-For header.
opsuba_api_url
String
Request URI.
out_times
String
Time required for interaction between the gateway and peripheral components.
remote_addr
String
Remote IP address.
request_id
String
Request ID.
request_length
String
Size of the entire request.
request_method
String
HTTP request method.
request_time
String
Time required for access.
scheme
String
Protocol.
server_protocol
String
Request protocol.
status
String
Status.
time_local
Date
Time.
upstream_addr
String
Remote IP address.
String
Time required for a remote connection.
String
Time required for receiving the header at the remote end.
String
Time required for returning a response from the remote end.
upstream_status
String
Remote status.
upstream_uri
String
Request backend URI.
user_name
String
Project ID or app ID of the user.
sec-dbss-alarm
Fields in DBSS alert logs
Table 15 dbss-alarm
Field
Type
domain_id
String
Account ID.
project_id
String
Project ID.
region
String
Region.
tenant_vpc_id
String
VPC ID of the tenant.
tenant_subnet_id
String
Subnet ID of the tenant
instance_id
String
Instance ID
instance_name
String
Instance name
alarm
Object
Alert object
source_type
String
DBSS
alarm
alarm_risk
String
Severity
client_ip
String
Connection IP address
database_ip
String
IP address for accessing the database
count
Long
Number of alerts
user_name
String
Database username
schema
String
Oracle schema
rule_name
String
Rule name
rule_id
String
Rule ID
sql_type
String
SQL execution type
sql_result
String
SQL execution result
db_type
String
Database type
sec-dsc-alarm
The reserved fields in DSC alert logs vary depending on the log types.
Table 16 AK SK leakage (aksk_leakage)
Field
Type
log_type
String
Alert type
region_id
String
Region
domain_id
String
Account ID.
project_id
String
Project ID.
leakage_ak
String
AK
source
String
Leakage source
find_time
String
Discovery time
account
String
Account name.
file_name
String
File name
file_suffix
String
File name extension
leakage_user_id
String
Sub-user ID of the leakage
leakage_user_name
String
Sub-username of the leakage
leakage_domain_id
String
Leaked account ID.
leakage_domain_name
String
Leaked account name.
url
String
Website URL of the leakage
Table 17 Risky OBS bucket files (obs_risk)
Field
Type
log_type
String
Alert type
region_id
String
Region
domain_id
String
Account ID.
project_id
String
Project ID.
bucket_policy
String
Public bucket/Private bucket
bucket_domain_id
String
ID of the account that the bucket belongs to.
bucket_project_id
String
ID of the project to which the bucket belongs
bucket_name
String
Bucket name
file_name
String
File name
file_path
String
File path
risk_level
Integer
Sensitive risk level
sensitive_data_type
String[]
Sensitive data type
privacy_detail
String
Personal privacy data details
file_type
String
File type
mimetypes
String
File type
rule_list
List<Map<String,String>>
List of matched rules
keyword
String
Keyword for matching sensitive data rules
available_zone
String
AZ
encrypted
String
Whether to encrypt data
Table 18 Sensitive data fields (db_risk)
Field
Type
log_type
String
Alert type
region_id
String
Region
domain_id
String
Account ID.
project_id
String
Project ID.
vpc_id
String
VPC ID
db_instance_type
String
RDS PUB
db_instance_id
String
Database instance ID
db_instance_type
String
Database instance type
db_instance_ip
String
IP address of the database instance
db_instance_domain_id
String
ID of the account that the database instance belongs to.
db_instance_project_id
String
ID of the project to which the database instance belongs
db_instance_name
String
Database instance name
db_name
String
Database name
table_name
String
Table name
field_name
String
Field name
data_type
String
Field data type
risk_level
Integer
sensitive_data_type
String[]
Sensitive data type
privacy_detail
String
rule_list
keyword
String
