Managing Security Reports
This section describes how to manage security reports, including enabling, disabling, downloading, sharing, editing, and deleting security reports.
 - Click
 in the upper part of the page and choose Security > SecMaster. - In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
 - In the navigation pane on the left, choose .
 - Manage security reports.
Table 1 Managing security reports Operation
Step
Enabling/disabling a security report
On the Reports page, locate the desired report and toggle the slider on or off.
- If the slider is toggled on, the security report is enabled.
 - If the slider is toggled off, the security report is disabled.
Editing a security report
- On the Security Reports page, locate the target report and click Edit.
 - (Optional) Edit basic report information.
 - Click Next: Report Choose. The Report Selection page is displayed.
 - (Optional) Select the report layout.
 - Click Finish in the upper right corner.
Deleting a security report
- On the Reports page, locate the desired report and click Delete.
 - Click OK.
Downloading a security report
- On the Security Reports page, click More in the lower right corner of the report you want to download and choose Download from the drop-down list. The report preview page is displayed.
 - On the report preview page displayed, click Download in the upper part of the page. In the dialog box displayed, select a report format and click OK. The system automatically downloads the report in the format you select to your local PC.
Sharing a security report
- On the Security Reports page, click More in the lower right corner of the report you want to share and choose Share from the drop-down list.
 - In the dialog box displayed, click the copy icon to share the link with others.
 - Then, click OK to close the dialog box.
