Reviewing a Workflow Version
This topic describes how to review a workflow version.
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the left navigation pane, choose Security Orchestration > Playbooks. Click Workflows.
- In the Operation column of the target workflow, click More and select Version Management.
- On the Version Management slide-out panel, click Review in the Operation column of the target workflow.
- Set Comments. Table 1 describes the parameters.
Table 1 Workflow review parameters Parameter
Comments
Select the review conclusion.
- If the workflow version is approved, the status of the workflow version changes to Activated.
- Reject. After the workflow version is rejected, the status of the workflow version changes to Rejected. You can edit the workflow version and submit it again.
Reason for rejection
Enter the review comment. This parameter is mandatory when Reject is selected for Review Comment.
- You can edit a rejected workflow version. For details, see Managing Workflow Versions.
- Workflow version status change:
If the current workflow has only one workflow version, the status of the approved workflow version is Activated by default.
- Click OK to complete the workflow version review.
Follow-up Operations
An approved workflow version needs to be enabled. For details, see Enabling a Workflow.
