Reviewing a Playbook Version
This section describes how to review a playbook version.
The playbook has been submitted by referring to Submitting a Playbook Version.
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
- In the left navigation pane, choose Security Orchestration > Playbooks.
- In the Operation column of the target playbook, click Versions.
- On the Version Management slide-out panel, click Review.
- On the Review Playbook Version page, enter the review information. Table 1 describes the parameters for reviewing a playbook version.
Table 1 Parameters for reviewing a playbook version Parameter
Comments
Select the review conclusion.
- If the playbook version is approved, the playbook version status changes to Activated.
- Reject. After the playbook version is rejected, the status of the playbook version changes to Rejected. You can edit the playbook version and submit it again.
Reason for rejection
This parameter is mandatory when the review comment is Reject.
Enter the review comment. This parameter is mandatory when Reject is selected for Review Comment.
If the current playbook has only one version, the version is in the activated state by default after being approved.
- Click OK to complete the playbook version review.
Follow-up Operations
An approved playbook version needs to be enabled. For details, see Enabling a Playbook.
