Updated on 2025-11-11 GMT+08:00
Creating a Workspace
Workspaces are top-level workbenches in SecMaster. A workspace can be associated with general projects and enterprise projects to support security operations in different scenarios.
Before using baseline inspection, alert management, log audit, and security orchestration in SecMaster, you need to create at least one workspace first. You can use workspaces to group your resources by application scenario. This will make security operations more efficient.
This section describes how to create a workspace.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management.
  4. (Optional) Complete authorization. Authorization is required only the first time you access the workspace management page.
    1. In the upper part of the workspace management page, choose Entrusted Service Authorization - Current Tenant.
    2. On the page for assigning permissions, select all required permissions (which are selected by default), select Agree to authorize, and click Confirm.
  5. On the Management page, click Create. The Create Workspace slide-out panel is displayed.
  6. Configure workspace parameters by referring to the following table.
    Table 1 Creating a workspace
    Region
    Select the region where you want to create the workspace.
    Enterprise Project
    Select your enterprise project from the drop-down list.
    This option is only available if you have logged in using an enterprise account, or if you have enabled enterprise projects.
    Value default indicates the default enterprise project. Resources that are not allocated to any enterprise projects under your account are displayed in the default enterprise project.
    Workspace Name
    Specify the workspace name. It must meet the following requirements:
    • Only letters (A to Z and a to z), numbers (0 to 9), and the following special characters are allowed: -_()
    • A maximum of 64 characters are allowed.
    Tag
    (Optional) Tag of the workspace, which is used to identify the workspace and help you classify and track your workspaces.
    (Optional) You provide a description of the workspace.
  7. Click OK.
  8. Choose Workspaces > Management in the navigation pane on the left. On the displayed page, check the new workspace.
